there are a few EX11.2 left on ebay stillâŚ
and fwiw, I found a fantastic old review that is extremely informative
here are some exerpts:
Good news about the EX10 driver
It runs Regulated Output on 16340 LiIon!!! so happy
modded the LED to High CRI 219b 4500k 9080 sw45k and output tripled, now
1 lumen low
225 max
60 gram carry weight
Nice. Someone at pelican must be a flashlight guy lol. You can get your own epp foam and do the same if you already have a case. Cutting with a hot wire is not too difficult just donât breathe it in!
WhoaâŚ
Got my second EX11.2 inserted brand new Surefire Red 123 the third on/off cycle it stayed on NO MORE!!!
Completely wiped the BAD little nuggets off both sides of this POS driver and mounted up a filed down 14mm to 12mm FETDD moppydrv. (I have 12mm Anduril drivers coming from Lexel)
. Sealed the bare contacts on both side of the pcb contact plate that used to be the driver with black epoxy paint, added the Golden Spring for easy smooth piston action, cheap $1.50 SS Clip and a 50.2 3volt emitter⌠just for gigâs
Almost 1900lm at T/O 1600lm at 30sec. and really HOT⌠lowest level is âmoonâ 4-5lm.
Very responsive piston/driver re-action zero failures to Turn Off
sorry to hear your EX11.2 driver was flaky
congrats on your hot rod driver upgrade
if the Anduril drivers had AA compatibility and firefly lows, I might be tempted
Pelican 1075, just 40 bucks on ebay
thanks for the nudge in the right direction
SweetâŚâŚâŚ. :+1:
Even with the problems reported for the EX11.2 it was too interesting a light for me to pass up, so after finding some rechargeable 3v batteriesâŚ
And replacing the emitters with sw30, sw35, and sw45kâŚ.
And adding trits so I can find them in the dark (and because I just like them)âŚ
I have used them for a few weeks now and have found that if I do a hard press of medium length I donât have any unexpected results. Short clicks, no matter how hard may lead to undesired results. The same for light clicks. The only failures that I have had have been when I didnât do both of these things.
fantastic mods!
is there any place I can get one of these?
I remember back in 2009 when I saw but couldnât afford one always liked the piston mechanism.
Thanks for sharing your tips and tricks to enjoy the EX11.2
I also find that pressing deliberately, not lightly nor quickly, is helpful.
Today I discovered another factor I can adjust⌠piston travel!
I have an EX11.2 that was pissing me off!
the button just seemed to have a mind of its own
it would not ramp, it would strobe when I did not want it to, it would not turn offâŚ
I blamed the LED, I blamed the battery, I blamed my thumb
the solution was to back the head out 1/8 to 1/4 turn
Nirvana!!!
all my clicks are now understood properly by the EX11.2 driver. I can go to minimum, maximum, strobe, sos, turn on, ramp up and down, turn off⌠all predictably.
speculation, why does unscrewing the head work?:
I think that when the head is fully tight, the piston pushes the spring loaded brass contact ring too close to the driver. The piston does not have enought travel to rebound properly, to allow the brass ring to lift itself away from the driver.
by loosening the head, we eliminate the excess compression from the piston pressing on the contact ring
with the head slightly loose, there is a bit more piston travel, and everything works properly
also note, different batteries have different lengths, cr123 are shorter than protected 16340, etcâŚ
fwiw, the head loses contact with the piston if unscrewed 3/4 turn⌠so dont do that⌠unless you want to use the light as a single mode twisty
Thats a feature, not a bug⌠LOL!
Thanks for that tip. I have now loosened the heads on the three EX11.2âs that I have and I will be testing to see if this makes it easy enough to let a less experienced person use these lights comfortably as I really like the beam profile after changing out the emitters.
thanks for joining the research team
I look forward to your observations
I often tuned my d10 and ex10 lights by filing and sanding to reduce the length a touch.
The trick that Okwchin taught me years ago about how to minimize effort needed to activate pistons was that there becomes a suction between the top of the piston and the light . Top here meaning the shoulder of the piston. People spend a lot of time looking at the o-ring thinking thatâs the problem . but itâs mainly the shoulder/suction and viscosity of lube . Ex models are obviously worse offenders . clean your shoulders .
