What blue light are you talking about? Does it have secondaries?
Thanks, I mean the Aux colours (R, Y, G, C, B, V, W) its stuck on B
Bottom of the updated Andril UI instructions
Are you changing the cell from the head or the tail? The tailcap shouldn’t be removed.
Try removing the head, tightening the tailcap as much as possible, then replacing the head.
Thank you for your comment, much appreciated. Unfortunately, this proposed solution hasn’t fixed the issue.
regards,
Michael
You did the 13 fast clicks and hold for reset?
(The other option of applying power while holding the button does not apply to the FW3A)
Thank you, yes; I have tried the reset numerous times - it doesn’t work.
Are you using a flat top battery?
Button tops are not recommended, although some of them do work. They can still act flaky if their length is borderline too long.
Try a different battery just to see if that changes anything.
Did you try confirming the retaining ring on the driver and tail cap are snug?
I’m not familiar with the latest versions with aux lights, but I think the functionality is mostly the same.
Thank you for your reply.
I’m not sure the type of battery - it came with the torch. It is pink and has the following inscriptions:
INR18650-35E
Samsung SDI
3 KI1T
I have tried to tighten the caps at both ends and the internal retaining rings, yes.
Is it possible that the chip in the torch burnt out somehow and is now working on limited functionality?
Can you post a link to where you bought it?
I looked at Lumintops website for a FW3A style light that has the aux leds and can’t find it.
Is this a modded or custom light?
BTW, you have to tighten the caps in a certain order if you loosen the tail.
You have to first loosen the head a little, then tighten the tail nice and firmly, then tighten the head.
Thanks, I’ll try the order of tightening that you suggested. This is the link to the torch, as you will see I paid a bit for it, so would love to get it working properly again.
https://www.liteshop.com.au/content/lumintop-fw3a-damascus-2800-lumen-enthusiasts-led-torch/
Yep, that’s an odd one. I don’t know much about it.
On one hand it says it uses a FET+7+1 driver and Anduril. That is normal for the FW3A.
On the other hand it says the firmware is: lume1 - FW3X Constant Current Buck-Boost
I’m going to guess that the Buck-Boost circuit is probably going to be built into the auxiliary board for the auxiliary LEDs. I really don’t know.
The stock driver uses the Attiny 85 MCU which has 4 pwm outputs (on the FW3A driver), but I don’t think it can control multicolor aux leds. 3 of those outputs are for the 3 channels which only leaves one other channel free. I don’t think a single output channel is enough. I’m not sure. Does anyone know?
I do know that other Anduril lights that use factory multicolor leds use the Attiny1634 MCU which has way more outputs.
I have not been on the forum much so maybe there have been changes to the FW3A driver? Did it switch to a 1634 or still the original one?
Back to MJB83, on a stock light I would say your symptoms sound like both the 7135 channels (1 & 2) stopped working and only the 3rd channel (FET) is working. With a stock ceiling level, only channels 1 and 2 are active. This would explain why you can’t ramp up or down and only a double click works. The double click of course is what activates the FET to give turbo output.
I’m hesitant to say that’s your problem, though because it’s rare for two channels to go out at the same time for no reason. Plus you’ve also got the auxiliary board which adds extra complication. I would definitely contact the store you bought it from if none of our suggestions fix it.
Here is a picture of a flat top battery. Note that the positive end does not stick up.
Does yours look like that or do you have the type where the tip is raised and sticks up higher? If it’s raised (button top), then it might be a tiny bit too long. Just a fraction of a millimeter can cause erratic behavior. I was originally using a Samsung 30Q with a button top that worked, but occasionally would make it act funny. I had to remove the button, or swap to a flat top, and it fixed all my issues.
The Damascus and Mokume FW3As come with a buck-boost + FET driver, not the standard 7+1+FET from the original FW3A. It sounds like the buck-boost channel is not working, but the FET is. Similar problem, same solution is to contact the vendor.
Those drivers also do not have reverse polarity protection, if you ever put the battery in backward even once, the driver is toast.
Thanks for the info.
Thank you for this. I will contact the Seller.
Is it possible to purchase replacement drivers?
Pretty sure that is a special driver. You will have to ask the seller. You paid a pretty penny, they should accommodate you.
The driver linked to in post 1540 is the Lume1 from loneoceans. I believe that is the special driver used in that fancy lookinh FW3a that has the problem.
Very neat driver. Seems it does use the Attiny1634 MCU. More info on it HERE in Loneoceans thread. A lot of components packed onto a board the size of a quarter.
My FW3A has lost all it’s functionality. Won’t lock w/ 4 presses, no clicky modes, and now dims and brightens with just one press. Is there a factory default that can be done?
Was the tailcap removed or loosened just before this happened? It has been noted that the tailcap MUST be tightened tightly FIRST and then the head screwed on.
How old is this FW3A?
