Simon’s got centering rings for his osrams that fit most of his reflectors. Strange that this would be the case.
Of course, the XHP70.2 in my Zebralight SC700d is slightly off-center. But there’s no centering ring, and the led to reflector size ratio means you can’t tell in the beam.
I sell most variants of the Osram white flats and it’s very difficult to get it centered with the gaskets. If the gasket was square cut and fit perfectly around it, it would be great but the hole is slightly too big. With an LED so small it can pull off the mcpcb with little force so there’s no easy solution.
It was brought up in another thread that the screws push the mcpcb off center, I have to use a tool to try hold it while I tighten the screws. Sometimes I’ve found that even if it looks centered perfectly, when I tighten with the reflector it’s off to the side, then have to push it way off center to get it centered in the reflector. Very annoying on some of the C8+ hosts.
I’d recommend getting pan head screws to replace the flat heads. I had to in my M2 because the factory flat heads forced the emitter of center. What then happened as an assembly is the emitter was ‘centered’ in the hole, but the reflected wasn’t sitting flat (off axis). This caused asymmetric artifacts. Pan heads allowed me to center it AND fully clamp it down.
Thank you for your input. Can you provide a link to the screws so I get the correct ones? This would be a great solution, I entirely forgot where I saw the comment and what the screws were
The Convoy’s drivers for SST40 (both 4 modes and 12 groups) don’t use PWM. That means better regulation and efficiency at modes below 100% than an equivalent 7135-based driver. That also avoids black lines on cameras.
On Lumeniac’s updated review the C8G regulation IMHO doesn’t look significantly better or worse than the M21A with SST40 or the equivalent C8. Nobody posted pictures of the updated driver, so we aren’t sure, but efficiency looks worse than the SP35 buck driver. He compares it against an 8*7135 C8 with XP-L HI but the XP-L HI has higher forward voltage than the SST40 so it’s natural that regulation with a linear (or buck) driver will be worse.
I don’t know why we are talking about the SST40 in this thread, but the Osram white flats have similar foward voltage to the SST40.
I sanded down the centering ring in my Osram C8 to focus it better. It has the petals around the hotspot, but they are mostly even, instead of on one side of the hotspot like it was out of the box.
If you want the throw of the Osram emitter with a perfect beam you need one of the lights with that fancy TIR optic that Acebeam uses on the E10, and L17.
