Someone needs to make a single 20350/18350 50mm GT mini sized LEP with a buck/boost driver. You may ask “why should someone make this?” Well because I WANT it. Now stop asking questions and get to work!
That’s awesome. I also love the lep lights. I only own two at the moment. I’m patiently waiting for one that has the option to zoom out. Even to zoom out just a little bit is all I ask. So it can be used for general lighting. Not sure if they can even make this possible. At least make the low a very low low imo.
I'm not sure there is enough space in a mini sized flashlight for the classic LEP module. There should be enough space for the one that is used in the Astrolux WP1 and WP2. That's only about 1 cm diameter and about 2 cm long.
About LEP flashlights being outlawed, that might be a valid concern, but not yet. The more we treat them with care, the longer it probably takes before these kinds of laws need to be put in place.... if they have to be put in place.
Well the 20350 version is 181mm long. With only one 20350 that could be shortened to 146mm and even more if a side switch is used. It would only last 25 mins on one 20350 but It’d be a pretty fun compact light and you could always switch to a 21700 if needed.
true, but a GT mini has smaller dimensions than a shorty L2K.
Discount code:
$30 off
use coupon: X1LU299
can be used on long and short version:
Long version: https://www.aliexpress.com/item/32949195871.html(link is external)
Short version: https://www.aliexpress.com/item/1005002237755766.html(link is external)
Can only be used up till April 30, 2021. Currently 10 codes available, but more can be added.
There is another code for $79 off, but I will use that for a giveaway. (only a few available)
I might get one with the $79 off code but first I have to find out if there’s any import tax. How much further can you see with this compared to the Nealsgadgets LEP? Is the difference noticeable enough to justify the extra price? Let’s say you turn it on from cold at 40% battery, will it still come on at the full 450 lumens? Also 20350 seem to be impossible to find in the UK. I managed to find a couple sellers that have the vapcell 18350 but all others are out of stock.
Good questions.
For both you need a scope to really see anything beyond a few hundred meters ;)
Yes, the 26650 and L2K are different beasts. The 26650 unbranded LEP is a fine flashilght for the money, but the L2K beats each and every flashlight out of the water, especially after the first 5 minutes
Thanks for the quick reply. So is the small brightness drop we see on turbo due to the laser heating up? If you let it cool down and turn it on again will it come on at full brightness? I want the 20350 version but will only use it for less than a minute at a time. I just want to be sure that it’ll come on at max brightness even with those weaker cells.
If you look at the graphs, you can see that the drop is very minimal (that's why this is such an interesting light). You won't be able to notice the difference. This is not a high power SBT90.2 flashlight that drops to AA flashlight territory ;) in 2 minutes
Ordered the short version with the coupon.
Thank you.
Order placed with coupon for long version. Thanks
What diameter and thickness are the filters?
Edit:
I found it on your main site, 55.7 x 1.8 mm.
Somehow I missed it on the first read through.
Anybody know where I can buy a clear glass replacement?
Awesome and thorough review Maybe someone who has purchased from Maxtoch can inform me: does the “full kit” option include the batteries and filters? Looks like “full kit” is the only option for both lengths of the Xsword L2K. The long version has a small photo of the flashlight with batteries, charger, and holster in the options thumbnail but does not explicitly list what comes with the full kit. The short version has no options thumbnail. Both show batteries under the “Available Accessories: Sold separately” section
Edit: Can confirm the short version full kit includes all the accessories shown in ChibiM’s review except for the lanyard.
I asked them and they said it comes with 20350 cells. Now the real question is what do I do? Do I buy this or the X80GT which is much more useful or do I wait till something better comes along.
That's the question :D
Both have their own purpose. The X80GT gets beaten by other high power flashlights, the L2K doesn't get beaten unless you pay $2500 more for the W50 or even more for a MicroFire
About outlawing LEP lights, I do not really see why that would happen. A LEP light has not remotely the intensity of a 10 dollar laser pointer, it is just a very throwy flashlight, useful and maybe annoying but not dangerous at any distance (the kcd, intensity calculated back to 1 meter, is 10+ times the sun, but when actually measured at 1 meter it is much lower because the beam is not collimated yet). And the laser inside is shielded wel from getting out just like similar lasers in engraving machines.
Mine arrived today, waiting for darkness to arrive so I can take it outside. It looks like it will be a lot of fun and serve no practical purpose.
Pip,how do you like yours? I’m about to buy one,but I’m at odds on the long or short version.
