Opus BT-C3100 not working out of the box
22 posts / 0 new
YuvalS
YuvalS's picture
Last seen: 1 day 2 hours ago
My friend have just bought a new BT-C3100 charger.
When connecting it to the socket, the screen lit up but nothing happen when inserting a cell.
Any advice on how to solve this?
My FW repository
My BLF/OL contest entries: 7th 8th 9th
sp5it
sp5it's picture
Last seen: 20 min 7 sec ago
Fill complaint and send back to seller to get working one. As simple as that.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
YuvalS
YuvalS's picture
sp5it wrote:
Fill complaint and send back to seller to get working one. As simple as that. Mike
Unfortunately, when finding out it is not working, he just put it aside and wait so now it is over a year and no longer under a warranty
My FW repository
raccoon city
raccoon city's picture
Last seen: 11 hours 56 min ago
If you don't want to return it, that's fine, but "just bought" and "over a year" ago don't jive together.  ;)
ChrisGarrett
ChrisGarrett's picture
Last seen: 33 min 38 sec ago
You have to press buttons to get it to start charging.
Chris
tatasal
Last seen: 15 hours 39 min ago
After inserting the psu, the display light will light up, NULL will show on the empty bays and will turn off when nothing is inserted while still showing the same status on a darkened screen.
Inserting an 18650 (as an example) will turn on the display light again, and if no button is pressed within a few seconds, it will still commence Charging mode at the default of 500ma.
Btw, the screen’s display should stay in a darkened state while showing “NULL” in all four, presumably empty slots. If it does still stay fully-darkened even a when a healthy cell is inserted, perhaps then there is something wrong with it.
patmurris
patmurris's picture
Last seen: 1 week 20 hours ago
Are you sure the cell is fine?
For instance a protected cell may sort of lockout itself and will show as NULL when inserted in the charger.
Did you try various cells and specifically unprotected?
CNCman
CNCman's picture
Last seen: 55 min 39 sec ago
Read the comments below the video, maybe this will help. Good luck !
https://www.youtube.com/watch?v=-tbaso1HkCM
YuvalS
YuvalS's picture
Thanks all for your replies, apparently I failed to described the problem.
Here is a short video showing side by side my working charger (on the right) and my friend's (on the left)
Hope it will explain the issue
My FW repository
ChrisGarrett
“He’s dead, Jim.”
Chris
tatasal
Yeah, dead as in ded Sad
NeutralFan
NeutralFan's picture
Last seen: 15 hours 25 min ago
The video certainly shows there’s an issue with the charger. Curious to know where your friend bought the Opus from?
I’d rather use my flashlight around the house than turn on the lights.
FlashKat
Last seen: 2 hours 27 min ago
Throw it in the trash.
I had one that malfunctioned and charged my battery to over 5 volts.
Not worth keeping.
I prefer XTAR chargers.
chops728
Last seen: 2 hours 47 min ago
The last 3 BT 3100 I bought had to update the fans in order to get a nonstop Discharge Cycle — They would overheat and pause several times for a 3000 mah cell
YuvalS
YuvalS's picture
It turns out that resurrection is not a myth.
A little adhesive tape to put pressure on the screen brought the charger back to life.
My FW repository
tatasal
Thumbs Up Beer
ChrisGarrett
I had a Kyocera stick phone that would do that with its little postage stamp sized screen and I had all sorts of tissue padding taped to the back.
Congrats on figuring things out!
Chris
CNCman
CNCman's picture
Great save YuvalS !! Thumbs Up
Cannot beat a cheap fix ! Big Smile
tatasal
My old crt TV used to do all sorts of vertical or horizontal picture hold problems and a slight tap on the ride side of the housing would bring it back to normal…though eventually even a mallet can’t bring it back to life.
NeutralFan
Glad you were able to fix it YuvalS! Still strange that it didn’t work in the first place.
YuvalS
YuvalS's picture
NeutralFan wrote:
Glad you were able to fix it YuvalS! Still strange that it didn't work in the first place.
Not so strange.. It is poorly engineered.
This is the 2nd Opus charger I had to fix out of the box.
The first one had a defective power socket.
In addition my other Opus malfunctioned and almost got my house on fire.
Opus chargers are very low quality and I don't recommend anyone to buy it
My FW repository
NeutralFan
My Opus BT-C3100 (version 2.0) that I’ve had since 2014 has been working flawlessly. Never had a problem with it, including the fan which is nice and quiet.
Maybe the quality has gotten bad, but it appears I got lucky with mine since so many people have had issues with them.
If mine ever goes bad, I will probably buy another one unless there’s another analyzing charger with the same features at a similar price.
