Ordered the ES03 Friday - good price! Used the BLF coupon code. Wish they had 4000K tint though. 6500K may be the least popular here.
Says will ship today -- can you confirm?
Seems like a decent buy, any idea what LEDs it uses mate?
Post #1000!
(at the moment)
SST-20's - it said in the BG listing - their listing is more complete, but you pay for it. FT has a good price for now, but of course it's risky for this "Smiling Shark" branded version. For me, gonna swap the LED's and driver anyway which eliminates some risk but I still won't know the quality and if the dims match up perfectly. The optic they use is a risk as well, but might be able to swap in something better.
1*LED + 1*COB 7-Mode 2500LM LED Flashlight w/ Focus Zoom
pure white(6500K) & red light / 2*18650/2*26650 / USB output / IPX4 waterproof / window hammer / LED power display
Head diameter: 60mm
Tail diameter: 35mm
HaikeLite HK04 Anduril UI Super Bright LED Flashlight
4*Cree XP-L HI / 2-mode (stepless/step dimming) / 5000LM / cool white / 3*18650 / USB-C rechargeable / IPX7 waterproof
Intelligent temperature control
Voltage: 3.7-4.2V
Head diameter: 56mm
Tube diameter: 46mm
Tail diameter: 50mm
Charging: 5V / 3A fast charging (When flashlight is charging, the switch lights up red; when charging is complete, the switch lights blue)
Says will ship today — can you confirm?
Hi Tom,
Your order is waiting to be packaged now, which will be shipped out as soon as possible. If there is any concerns, please feel free to contact us in ticket, we will do our best to help. Thank you.
1*Cree XHP35 LED / 6-mode / 2000LM / cool white / 1*21700/1*18650 / USB-C rechargeable / clip / lanyard / IPX8 waterproof (2m underwater)
Voltage: 3.7-4.2V
Head diameter: 28mm
Tail diameter: 26.5mm
1m impact resistance
Side key lock function
High-efficiency constant current circuit, intelligent temperature control, to ensure maximum safety and stable performance
Battery power detection function, keep abreast of the remaining battery power
Thanks!
You guys are killing us with the 6500K LED tints - all the HK04 options are 6500K
FastTech New Arrivals! USB Powered Rainbow Projector LED Night Light Atmosphere Floor Lamp
The farther the distance, the greater the projection that the sunset light can project on the wall or ceiling. The light casts amazing colored circular lights on the wall, ceiling and floor.
Powered by USB 5V/5W, 1.5m long cable with switch.
Adjustable Height: This lamp is for ambiance! It can not only be place on your desk but also be adjusted to place on the floor! It casts a wonderful ray on the wall. No matter when you leave it on, it lights up the walls with the sunset-/sun-liked/rainbow light.
180 Degree Adjustable: The light projector can tilt 180 degrees according to your needs and stand upright or project in different directions. Perfect for creating a warm and romantic ambiance. It is a perfect gift for you, your lover, your family, your friend, etc.
3mm wire diameter
“JETBeam KO-02 LED Flashlight”:https://www.fasttech.com/p/9738205 1Cree XHP35 LED / 6-mode / 2000LM / cool white / 121700/1*18650 / USB-C rechargeable / clip / lanyard / IPX8 waterproof (2m underwater) Voltage: 3.7-4.2V Head diameter: 28mm Tail diameter: 26.5mm 1m impact resistance Side key lock function High-efficiency constant current circuit, intelligent temperature control, to ensure maximum safety and stable performance Battery power detection function, keep abreast of the remaining battery power !https://img.fasttechcdn.com/973/9738205/9738205-1.jpg! !https://img.fasttechcdn.com/973/9738205/9738205-5.jpg!
What's the UI on this one?
Click for ON/OFF or hold?
Also, are the modes from High to Low or "normal" L-H?
I had to goggle it, and acto the bmengineer review, it’s kinda bad.
Green beam (hey, it’s a Jetbeam, so whaddya expect? ), and a horrible UI that always starts on turbo and you gotta click to get down to moonlight (after being sufficiently blinded by turbo).
I had to goggle it, and acto the bmengineer review, it’s kinda bad. Green beam (hey, it’s a Jetbeam, so whaddya expect? :laughing: ), and a horrible UI that always starts on turbo and you gotta click to get down to moonlight (after being sufficiently blinded by turbo).
I googled that too but it’s V1 in the test.
This one is V2 if i’m not mistaken
JETBeam BR10 PRO LED Flashlight Bike Bicycle Front Light
1*Luminus SST-40 LED / 6-mode / 1*21700/1*20700/1*18650 / 1380LM / cool white / USB rechargeable / IPX8 waterproof (2m underwater)
Intelligent temperature control system to maximise the lifespan of LED
360’ rotation to adjust beam angle for different applications
Power indicator function to know power level at anytime
Voltage: 3.7-4.2V
4*Luminus SST20 LED / stepless dimming / 4000LM / cool white / 1*26800/1*26650/1*21700 / lanyard / IPX7 waterproof
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
Spring: Copper alloy silver-plated spring with ultra-low internal resistance
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
4*Luminus SST40 LED / stepless dimming / 7000LM / cool white / 1*26800/1*26650/1*21700 / lanyard / IPX7 waterproof
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
In Stock! Manker T02 LED Flashlight
1*Cree XHP35 LED / 6-mode / 1500LM / IPX8 waterproof / 2*14500/2*AA / power display / overdischarge protection
Beam range: 144m/211m (AA/14500)
Voltage: 1.5-3.4V/5.4-8.8V
Current: 1A
Ordered a HK4S, SST-40, brown - good price!
Is that a candidate for a QB26800 cell retrofit?
