While I’ve used Atmel Studio (on Windows) for firmware before, I’ve never used it for Anduril. You might try following this guide.
Also, don’t forget that you’ll want to use the version of Anduril found at my branch because it’s likely the only one out there that has AVR 1-Series support.
I can try helping with the hwdef and cfg files, but it’s gonna take me a bit.
Yep that’s the guide I saw, but I followed Agro’s advice , I installed an Ubuntu VM, followed Toykeeper’s instructions , and compiled her branch to check that the basic stuff works fine, all very straightforward.
Then for your branch (yes it’s the one I was using ) I got the extracted DFP, put its path in your build script, changed 412 to 1616 in it and put the build script in the anduril folder.
Is there something more to do ? (like specify somewhere to use your build script )
I used the make command and it compiled all files without issue, mine too.
Then in atmel/microchip studio I used device programing, put the hex file in memories/flash and then hit program.
The driver turns on and off on the lowest output and that’s all, no ramping, so I must have an issue somewhere in my hwdef or cfg files, or maybe elsewhere.
Ok, you’ve got it compiling and flashed, that’s great progress!
Do you still have it wired up to use TCD? No air-wires or other things for testing? Could you upload your hwdef and config files, perhaps to PasteBin so-as not to overwhelm this thread?
I should have put less stuff in it for basic testing though.
Edit : airwire from PB0 to PC0 (and PC1 since they’re connected on pcb), I tried with and without pull-up on PC0 and PC1 in the bottom of hwdef, but maybe I should cut the traces ? It worked fine with your test_tcd code even though pc0 and pc1 were connected together.
In hwdef for the Aux, you don’t need the separate AUXLED_x_PORT definitions, just the single AUXLED_RGB_PORT that you already have. AUXLED_RGB_DDR and AUXLED_RGB_PUE can be removed
In cfg I’m not sure about starting the ramp at 0, usually you’d want it at 1 or higher.
If you’re going to try with the airwire from PB0, I definitely wouldn’t set the pullups on PC0 and PC1. By pulling those pins high, that could/will interfere with your PWM signal.
Don’t forget to set PA6 as output. You might try setting it high to see if you can get the higher current range to activate, though I’m not sure that would actually tell you anything. Just a thought.
I’m a bit confused with the instructions for Linux on the first page, after putting the DFP path into your build script, what do I do with it ? Does it just need to be in the anduril folder? with or without it in it using the command ”make” compile everything without errors, isn’t this strange ?
All you should need to do is update the DFP line in the build script with your directory for those files. It’s strange that it would build successfully without them. If you run the following commands, what versions does it say you have?
I’m on avr-libc version 2.0.0 and gcc-avr version 5.4.0. I’ve heard there are other (development) versions available that might have the device packs baked-in.
I made a test board with one 7135 and the same pinout as your BLF_Q8_T1616 so I don’t have to touch anything, it doesn’t work, so there is something wrong either with the building or flashing.
Could you send me an hex file for the BLF_Q8_T1616 ?
edit : never mind that was a bad solder joint, building and flashing is ok.
If any of the “06” (Sofirn) builds require custom hardware, I’ll re-number them under the “16” brand.
In fsm-adc.c, why does the temperature shift right 8 and then left 6, instead of just shifting right 2 bits? It seems like this throws out some potential extra precision. Also, it uses 32-bit math to avoid 2 bits of potential overflow, but then sheds 6 bits, so I’m wondering if that might be avoidable. Not sure how many clock cycles it takes for the 32-bit operation on this MCU, but I’m trying to keep interrupt handler timing as short as possible.
In tk-attiny.h, it sets the base clock speed to 5 MHz, but could have also used 10 MHz. I can see reasons for either one to be used, but I’m wondering how the PWM speed and power usage look in both configurations. Have you measured this?
The SP10S build has pretty unusual ramp values and looks like the low channel is very low. Would it benefit from some extra sub-ramping on the low channel during the bottom portion of the high channel’s ramp? Not sure if that could provide extra resolution or not, especially with dual voltage.
Sorry about how messy it is to add a new MCU. I’ve been thinking about ways to make this process easier and cleaner, but I’m not sure what the best approach is or when it’ll happen.
The 06xx builds for t1616: Sofirn approached me about working with them to convert these models to use the t1616. So these are pre-production builds, but could hopefully one day (soon?) be actual Sofirn lights. Feel free to number them however you see fit!
The “shift right 8 bits” was part of code I copied right from Atmel (attiny1616 manual page 435). Then I saw you left aligned things. I didn’t combine the two, but it looks like that could be done. In general though, that chunk of code was just a copy & paste from Atmel. I didn’t bother trying to optimize it for our use case.
The power usage between 5 MHz and 10 MHz is minimal unless we’re trying to really stretch runtime on low modes. You can see some test results here
I agree, the SP10S ramp is a bit unusual. And yes, that’s because the low channel is very low. But the lowest setting of the big channel is appreciably higher. I think the high channel is a straight 3.13V feed while the low side adds a 4.7 kOhm resistor. I’m not that great with customizing the ramps, and flashing new builds meant tearing the light apart again, so I rolled with a “yeah, that’ll work” ramp. I’d be up for trying something new though!
Oh, nice. If they’re pre-production builds for things people will eventually be able to buy, they can keep the Sofirn manufacturer ID. I’ve been so out of touch I didn’t know those were in progress.
About shifting bits around, it probably doesn’t matter. It works now, and can maybe be optimized later if necessary, but there’s not really any need yet.
For 5/10 MHz, I just measured the PWM speed and got 19.22 kHz… which suggests it’s either fast PWM at 5 MHz or phase-correct at 10 MHz. Looking at the code, it appears to be 5 MHz with fast PWM. I haven’t measured that before on this MCU, but older models had issues with fast PWM at low levels and at full output, since each pulse would turn on and off at least for one cycle regardless of the target value… so 0/255 wasn’t fully off and 255/255 wasn’t fully on. So it may be worth some investigation to see if that’s still the case, and maybe switch to phase-correct 10MHz. But that’s just a minor potential optimization for later.
If the SP10S is a pain to reflash, it would definitely be a pain to do fine adjustments of the ramp. Sometimes it’s possible to improve low-end resolution by treating the low channel as extra “bits” for the high channel, but only if the power levels of each are well-balanced and stable at different voltages. If that’s not the case, or if it’s not feasible to do the testing involved, it’s better to just leave it as-is.
Also, I noticed the t1616 doesn’t seem to reset eeprom while flashing. Not really a big deal, since factory reset exists… but the flashing script also doesn’t set any fuse values. Does it ever need fuse values set?
Anyway, the 1-Series branch is merged into my anduril2 branch, and will likely also get merged soon-ish into the fsm branch and trunk. I also added some new builds. I hope this will make things a bit easier for everyone.
I do believe it’s 5 MHz with Fast PWM. I haven’t noticed any unusual things with PWM, but I also don’t have a ’scope to do a deep dive. Is there anything I can do with “normal” tools to check to see if the old Fast PWM problems are being exhibited?
With some back-of-the-napkin math / guesstimates based on LED vF and resistor values, I’d say the high channel is around 1.5 amps and the low channel is around 0.7 mA. So 1/255 of 1.5 amps is around 6 mA, much higher than the highest low channel value. The best option would probably be to replace that 4.7 kOhm resistor with a smaller value… oh well.
You’re right, I don’t think the t1616 resets eeprom when flashing. When needed (like when moving from Anduril1 to Anduril2), I’ve just done a factory reset. Speaking of that, one thing that LoneOceans did with the Lume series drivers was to prevent thermal calibration during a factory reset since he used a pre-calibrated temperature sensor. These 1-Series chips are also pre-calibrated, so there’s no need to auto-calibrate on reset. I didn’t check to see how to prevent this.
Fuses… thankfully I’ve seen absolutely no need to change fuse settings on the 1-Series. Most things we used to do in fuses can now be set at run-time (clock settings, brown-out settings, etc).
Sorry it’s me again, never mind my previous post, that was just a bad solder joint on my test board :FACEPALM: , compiling and flashing works fine. I did further testing on my driver and the problem comes from the boost enable pin, it’s floating at ~0.8V whether it’s off or on, I also assigned it to others pins (PB1, PB4, normally it’s PB3, for testing I enabled pull-up on PB3, which for some strange reason is at 2.2V instead of 2.8V) same result, then I assigned it to PA5 and it works : 0V when off, 2.8V when on. How does that make sense ?
Hmm, I wish I had a good answer for that. Is it possible that it has something to do with the driver design? Not saying it’s wrong or bad, just something specific to hire it’s laid out?
