4*Cree XP-L HI / 2-mode (stepless/step dimming) / 5000LM / cool white / 3*18650 / USB-C rechargeable / IPX7 waterproof
Intelligent temperature control
Voltage: 3.7-4.2V
Head diameter: 56mm
Tube diameter: 46mm
Tail diameter: 50mm
Charging: 5V / 3A fast charging (When flashlight is charging, the switch lights up red; when charging is complete, the switch lights blue)
Your order is waiting to be packaged now, which will be shipped out as soon as possible. If there is any concerns, please feel free to contact us in ticket, we will do our best to help. Thank you.
Voltage: 3.7-4.2V
Head diameter: 28mm
Tail diameter: 26.5mm
1m impact resistance
Side key lock function
High-efficiency constant current circuit, intelligent temperature control, to ensure maximum safety and stable performance
Battery power detection function, keep abreast of the remaining battery power
The farther the distance, the greater the projection that the sunset light can project on the wall or ceiling. The light casts amazing colored circular lights on the wall, ceiling and floor.
Powered by USB 5V/5W, 1.5m long cable with switch.
Adjustable Height: This lamp is for ambiance! It can not only be place on your desk but also be adjusted to place on the floor! It casts a wonderful ray on the wall. No matter when you leave it on, it lights up the walls with the sunset-/sun-liked/rainbow light.
180 Degree Adjustable: The light projector can tilt 180 degrees according to your needs and stand upright or project in different directions. Perfect for creating a warm and romantic ambiance. It is a perfect gift for you, your lover, your family, your friend, etc.
3mm wire diameter
I had to goggle it, and acto the bmengineer review, it’s kinda bad.
Green beam (hey, it’s a Jetbeam, so whaddya expect? ), and a horrible UI that always starts on turbo and you gotta click to get down to moonlight (after being sufficiently blinded by turbo).
1*Luminus SST-40 LED / 6-mode / 1*21700/1*20700/1*18650 / 1380LM / cool white / USB rechargeable / IPX8 waterproof (2m underwater)
Intelligent temperature control system to maximise the lifespan of LED
360’ rotation to adjust beam angle for different applications
Power indicator function to know power level at anytime
Voltage: 3.7-4.2V
