Is it green I hear you wonder…
I need to sleep but…
Wow! More output than the FW21 Pro. I wonder how the sustained output compares to it.
I can’t believe my XPL-HI came set to Advanced ramping with Max ramp set to Turbo and the LH351D came set to the scandalous Simple stepped UI with the almost hidden Turbo, and a defective switch to boot!
FIREFLIES make up your mind, how do you want to sell the ill-fated ANDURIL II ui? and secondly are you FIREFLIES or FIREFLYLITE?
Is the hotspot more green than the FW21 Pro/S43S?
Both step down sharply after around 25-35 secs depending on ambient temp, the Pro steps down harder.
All the other lights look rosy or neutral next to the E12R LH351D.
