[Info-Thread] Wurkkos FC11 - 18650 EDC, LH351D 5000K 90CRI, USB-C, magnetic tail
86 posts / 0 new
contactcr
Last seen: 1 hour 20 min ago
Lost the bin lottery I guess
gchart
gchart's picture
Last seen: 2 hours 43 min ago
Better slice it Wink
contactcr
I think I may just outright replace it. Even the CRI seems a few points less. I think they changed what they feed the dog
I sliced it after all:
hodor
hodor's picture
Last seen: 4 hours 7 min ago
Don’t know if (known) bug or error with instruction manual.
In both modes, continuing to hold button from OFF does not do the intended action and instead switches between modes.
Excerpt from manual below.
Stepped mode:
From OFF, hold 1 second to Eco, then keep holding to cycle through stepped modes.
Ramping mode:
From OFF, hold 1 second to Eco, then keep holding will adjust brightness steplessly.
iamlucky13
Last seen: 53 min 23 sec ago
You could try with the front lens off in case an AR coating is affecting it.
contactcr
It’s a plain lens, no change.
jon_slider
jon_slider's picture
Last seen: 1 hour 41 min ago
thanks for posting your data captures (I summarized to show change in duv and R9):
still smells like a dogfart
Midnite
Last seen: 11 months 3 weeks ago
g_damian wrote:
there is a bug in ui: if turbo or strobe is accessed directly from off, long press activates last used mode. From that state, flashlight cannot be turned off and mode cannot be changed. Only action is double/tripple click to go back to turbo/strobe and then flashlight can be turned off,
From what I’ve found, the bug is only when the flashlight is in stepped mode. I don’t have this problem when in ramping.
Mag-lite XL50, Fenix PD35v2, Zebralight H600Fc MKIV, Emisar D4V2, Sofirn SP-40, NG C8+ W2, BLF LT1, Manker MC13, Manker E14 III, Wurrkos FC11
Swabs
Swabs's picture
Received the FC11 today. Battery is charging, so I am currently using a Samsung 35E protected button top to test out the light. Liking it a lot so far. The magnetic tail cap is pretty strong..
Here it is stuck to the Real Steel Flying Shark. I even moved the blade around a bit, but the FC11 held on.
My Future's So Bright...well, my flashlights are anyways.
Tendou
Last seen: 1 week 4 days ago
So how’s the pwm for this light?
raccoon city
raccoon city's picture
Last seen: 9 hours 11 min ago
@Swabs:
Nice Firesticks!
(the succulent in your yard.)
Swabs
Swabs's picture
Tendou – I don’t notice any PWM. I think the light is really good.
raccoon city – Thank you.
Tendou
Thank you. I will get one then
Beamshooter
This flashlight is pretty amazing for the price. I am very happy with it. But is there any special handling of the battery necessary?
rdhood
Last seen: 11 months 4 days ago
This has been my EDC since I received it. It has a great (for me) UI, and a nice beam. Its easy to carry… it has never accidentally turned on in my pocket. The light is usable.. good temp, no tint, high CRI. It has C-C charging that works. Its a really nice flashlight. My only wish is that the side switch was lit when the light is turned off.
NullReferenceEx...
NullReferenceException's picture
Last seen: 9 months 5 days ago
Hi everyone! This is my first hi CRI flashlight and I really love it for a beautiful 4000k tint. I’ve got it also to have more sophisticated ui than standard commonly used ‘lo-med-hi’ in many cheap flashlights. I own it for like 4-5 months and have mainly positive emotions from usage.
However I’ve got some bugs that frustrating me a little:
1. Low voltage red light starts blinking at something like 3.9-3.8 Volts. It seems to me that this is clearly more than it should be. This problem occurs with any cell I have, even with standard Wurkkos 3000mAh 18650. This problem was from the very beginning and is not that awful.
2. Turned on flashlight sometimes won’t turn off untill you either change brightness or activate turbo or strobe. Especially if the flashlight was on for a longer than 5~10 minutes. This problem started to bother me about a month or so ago.
3. Memorized brightness level falls to eco after you turn flashlight in eco mode from off (with long press). Like if you turned off on middle level, then long press to eco, then turn off, then turn on again and ‘taa-daa’ you’re in eco again.This problem has appeared quite recently and is really disturbing.
I have to admit that it is a ‘new version’ of the fc-11 model.
If you have any ideas of how to make this bugs gone, it would be really nice!
However I believe that all these problems are refer to my own instance only and hopefully will not occur anymore else.
In any case I’m really thinking to get myself 2700k version though.
Cheers!
May 'Stackoverflow' be with you!
Lightbringer
Lightbringer's picture
Last seen: 2 hours 53 min ago
Whenever a light starts going mental, check allllll the retaining rings.
If one’s loose, tighten it. If they’re all tight, loosen them, jiggle the board to make sure it seats correctly, then retighten.
You have no idea how many mental lights were fixed by just doing that.
NullReferenceEx...
Thanks for the hint! The hack is that this flashlight hasn’t got any retaining rings inside. The driver as well as a bezel seems to be glued.
All I can do is to clean contacts.
The flashlight did not fall or sink, no dust inside, cell wrap isn’t damaged, nothing moves or dangles inside…
Never mind! That’s not that big problems for the 25 bucks light.
DNA
Last seen: 2 days 3 hours ago
Looks like they just announced the FC12.
More lumens, and a tail switch.
Dan
Sudsy
Last seen: 4 hours 33 min ago
Dan
I’m liking it already! Let me know if you hear more about it, I’m going to start searching.
anonymous_user
Someone posted about it on reddit. Heres some details they mentioned:
  • EDC Tactical 18650 Light
  • Type C charging port
  • Luminus SFT40 LED
  • 345 Meters thrower
  • 2000lm output max
  • Power Indicator
  • Length X diameter: 136.5mm*24mm
timbo114
timbo114's picture
Last seen: 2 days 9 hours ago
Got a few FC11s, I’d certainly grab a FC12
Wurkkos
Wurkkos's picture
Last seen: 22 hours 34 min ago
FC12 will release soon next Monday on our official website
Sudsy
The fc12 listing is active on the site, but I don’t see the color temperature specification or options to select a preferred tint. What is the CCT of this model?
There is an option for a black body or purple, which is cool. I’d like to see some pics of the purple body.
cothyhu77
Last seen: 23 hours 44 min ago
The SFT40 is only available in 6500K right now. I’d like to know more about the UI and the driver in the FC12 though.
These pictures of the purple prototype (among others) were posted on reddit recently: https://imgur.com/a/jpK8hp9
