If you use a wall charger, make sure that the current is below 300 mA and no more than 150 mA would be strongly preferred. Going lower than that would be good for cell longevity.
Soā¦with some chargers you can but I still recommend GT Nano charger instead.
āAdvanced interface settings
There are also advanced interface settings that can be configured to suit your tastes. In particular, it is possible to configure the function:
āButton Led on while GT Nano is OFFā that allows you to set the activation or deactivation of the LED under the power button when the flashlight is in OFF. āBattery Level Blink on Button LED onlyā : If set to āEnableā, the cell voltage will be signaled by a series of flashes of the LED under the power button and not the main LED as set by default.
āButton LEDā that allows you to disable the LED under the power buttonā
It's a big review - scanned it and can't find it. Any idea where?
Just checked in the code in NarsilM vers 1.3 latest. Here's a snippet of code in the 16 msec timer that handles ramping:
case 2: // lo->hi rampLastDirState = 2; if (rampingLevel < MAX_RAMP_LEVEL) { outLevel = ++rampingLevel; savedLevel = rampingLevel; } else { rampState = 4; SetLevel(0); // Do a quick blink _delay_ms(7); } SetLevel(outLevel); break;
What this code above does is blink the main LED by turning off the main LED for 7 msecs when "MAX_RAMP_LEVEL" is reached. There's no options or conditions - this will always happen. Same goes when you hit the bottom of the ramp.
Im not sure I understand your questionā¦ because switching to lower mode is not the same as checking battery level
here is the instruction manual:
and the instructions in the manual, for moving the battery level blinks from main to button, and to turn off button:
but battery level flashing only happens IF you use the correct keystrokes to cause it to reportā¦
soā¦ I wonder if you are using the button to give battery level intentionally, or by mistake?
or IF your light is stepping down by itself, and blinking, because the battery is too low, then you need to recharge the batteryā¦ to stop the step down and low battery warning (I dont know if that is a feature of this light)
or IF you mean the Auto Step Down based on the temperature, that feature can be disabledā¦ its in the Manual, item #7ā¦ but I dont know if That is what you mean, cause the manual does not mention any blinking for that.
Iām glad I read this, while Iāve only charged the 4 10180 cells once in my nitecore 4-slot charger I thought I was being really clever putting hex nuts under one end so the batteries would reach the charger terminalsā¦not the smartest idea, I think they were being charged @300mA. Iāll just use the little charger that came with it. They charge pretty quick.
Thanks, good info. Iām a bit of a led light noob. Few months ago I didnāt own any now I have aboutā¦coughā¦fourty-ish maybe. I know nealsgadgets sell the long nano body tube but canāt find them on BG, Ali-x or DHgate. Is Neal the one of the only paces that stock them? Thanks
I was thinking about getting some GT Nanoās as gifts for non-flashaholic friends, but I have some questions Iām hoping others with GT Nanoās in hand can answer:
The Nano shouldnāt get anywhere close to burning hot like a D4, correct?
I know the flashlight when on has Low Voltage Protection built-in, but is it possible for the button light or parasitic drain to drain the battery under 2 volts? Iām going to tell them to disable the button light and physically lock out the flashlight, but I worry they may forget to.
Does the included charger have reverse polarity protection and damaged (under 2 volt) battery protection? Or will it try to charge irregardless and cause the battery to vent? I know Lumintop had to squeeze a lot into such a tiny package including the charging attachment, so I worry for my muggle friends. Donāt want them to set something on fire.
They drop down from turbo after less than a minute Iāve found but you can double click & go back into turbo or a less lumen version depending on heat temp. They donāt get really hot like other lights can. I unscrew the tail cap so not sure how low parasitic drain gets. I think the charger has protectionā¦hang on Iāll get the manual. The manual says nothing about reverse polarity protection with charger. It just say you āmustā put battery in light the correct way. It says itās got a small parasitic drain while light is off so if not using it for longer period they recommend removing battery or unscrewing tail cap which I think should answer one of your Qās. They are fun little lights, you can get a longer battery tube too.
Muggles know how to destroy a battery, no matter how well protected your flashlight is
My Nano has 20 micro-amps parasitic drain when off, that drains the full battery in half a year.
About the charger: putting in a battery gives a bright red light telling that it is charging. Putting in no battery gives a bright green light. Putting in the battery reversed gives a weak green light, when unplugging the USB that weak light goes off.
This suggests that with a reversed battery the charger at least does not happily starts charging the wrong way because then I would expect the red light, and it does something different than with no battery which suggests that the wrong orientation may be detected.
But then, maybe those different colours may be randomly caused by the electronics and nothing is protected at all. At least a small battery gives a small fire
Actually, Iāve found low-CRI seems to be what muggles prefer. They like the high output, or in the case of the nano, the high throw that low CRI led provides.
Many muggles even prefer cool-white tint to neutral or warm white simply because cool white looks brighter! ugh!
The distinction of high-CRI versus low-CRI seems most noticeable to flashaholics like us.
Itās strange for me to hear how some people talk about the Nano in terms of functionality. They pick up additional pipes for him, trying to deprive him of what he was actually created for: mood. In my opinion, disfiguring it by extending it by 10440 is the same as attaching an extension cord for 2 18650 to Emisar.
Thatās a great post and exactly what Iāve posted to this thread more than once! This Nano is revolutionary all itās own. A teeny, tiny creature that goes way above itās size for throw no matter for how long the duration.
Leave it to the āexpertsā here who want to change it into something itās not by doubling itās size and even changing out the LED. But in their defense, itās what makes BLF what it is.
I even bent and went into the all encompassing finding out what 10440 tube that would work with it. I have to admit I have no problem with that but itās fascinating how this thread has become into letās make it into something it originally wasnāt intended to be and maybe it might fry the LED.
Anyway, this tiny thing completely stock is what it was meant to be. Itās a tribute to how far things have come to have such a tiny thing that can throw so far as it does. This really wasnāt meant to be an EDC but a show piece of miniature tech. Maybe not too far in the future there will be 10180 size cells that will have much more capacity.
Meant to be can be from two perspectives: the manufacturerās view or what makes sense as a BLF development.
The big GT was a BLF design made into production by Lumintop. Then Lumintop initiated the mini-GT for one 18650 and we loved that (I did). Then came the micro for 14500, loved that even more, and we all expected the next step would be a AAA-size light, we even hoped for NiMh compatibility. If then Lumintop comes with a Nano with a too short tube and a silly too small too low capacity 10180 battery, it makes sense to be disappointed.
But if you skip the story, the Nano is a lovely little light that amazes, and Lumintop did a great job on it (except on the charger, seems a not so great afterthought when they found out that a USB-C port did not fit)
Donāt forget that when the GT nano was in development, everything pointed to a 10440 battery, then it came out with a 10180! So in my point of view is a expectation vs reality issue.
BTW I bought it anyway, but also have ordered the tube now.
