Here are the results I have. Granted the Lexel driver is going to push the 70.2 to near its highest Lumens that most lights cannot do, so its not a fair comparison. But its doable.
Left XHP 70.2 …… Right Luminus SBT 90.2.
The led was from Digi-Key at XHP 70.2 5700K before dedoming.
The driver is 12v 8amp from Lexel with 5v power supply for pump.
Runs cool and only gets warm in warm weather.
The dedomed Digi-Key XHP 70.2 5700K performed much better than the 6500K dedomed Mtn. Electronics led.
12V 8Amps on turbo
1.372,969cd
9,200lm
2,343m throw
Specs for Luminus SBT 90.2 not water cooled.
3V 22 amps on turbo
1,829,513cd
5800 lumens
2700 meter throw
It is hard to beat the XHP 70.2 when driven hard.
A lot has been promoted about the SBT 90.2, but the proof is in the beam shots.
When standing behind the two lights, I give the 70.2 my vote.
Yes I believe the BLF GT90 is a far better light and worth the investment over the K75 you get more cells so more shenanigans and a better UI, when I had the K75 I hated the UI the only acebeam light I have left and like the UI is the L16.
I would say take a look at smaller LEP’s the larger LEP lights are super fun but horribly impractical unless you are shining a mountain side for giggles.
I recently got into smaller LEP’s but since Canada has weird issues things having a Class 3B laser they tend to get refused and sent back so with somewhat limited options I picked up a Astrolux WP1 and boy is it a contender for something so small it has a very usable beam and very respectable amount of throw mine measured 355kcd~.
My MR175 eats my original BLF-GT for breakfast the BLF is not even close so I think even the latest top thrower still would not come close to my 10+ year old MR175. Its just not that practical BIG unit. The battery back is separate (back pack).
I was only using it a few weeks ago sitting on a cabins veranda. I set up a pair of binoculars on a tripod and was spotting foxes 1.5km away on the next ridge. If only I had a gun that could shoot that far.
But that is neither a true handheld flashlight, nor is it even close to the 350 dollar or less range the OP asked about. He already left off the MF05 due to the price, and it tis cheaper than this military flashlight.
Mine is not an MF04S, it is an MF04 which is less lumens but further throw….2700 lumens @ 2416 meters of throw. I have had no issues yet with the UI, but admittedly such ridiculous throwers are just too big to actually be used much. It is more just for impressing friends and neighbors. It is not actually the light that most impresses people though. That would be the GT micro, modified with the Osram emmitter and has 809 meters throw from that small 14500 battery. The GT Nano is also impressive, but that tiny 10180 battery wont impress for long before totally drained.
I have never seen much practical use for a LEP light. Unless used as a signal light for rescue in a forest, I can see nearly no practical use for them. I greatly prefer at least some usable spill. I guess, being an actual laser, it could be used for nefarious and illegal purposes to blind someone, but it is just too small of a spot to be used to see things with it. I love throwers, but the LEP has no interest for me at all.
True, i had the mf02s and the UI never really bothered me per se, i mean i would like a better one but it would’nt stop me from buying one f those lights.
I almost put the mf02 on here, and that will probably be my next light unless i can score a original Lumintop GT NW, which i will just grab that. I guess i didn’t put those on here originally because i was thinking BIG reflector, BIG emitter - so an sbt90,2 only. But, you bring up a good point those xhp35 throwers do contend well with the throw. I have the brass GT Micro coming in, its my first micro, so i am interested in the wow factor :+1:
I think I had a little to much to drink the night I posted in this thread. It had very little to do with the topic sorry.
It sure is a special light more on the fun side than practical. Got it from a member over on CPF back in 2013 another member BVH purchased three of them.
I just realized I only have one picture of it. It’s a pic of all my big HID & short arc lights (see below).
I got my MR175 for around the same price as a BLF GT90 but the shipping down here was almost the same cost again.
I looked up that mr175 the other night too, wow! That thing must be a beast. That is outside my wheel house, I probably couldn’t figure out how to operate it lol.
I think I may go with the lumintop sd90- new releases :
90mm head (a little small, wish it was 100mm or 105mm)
Sbt90.2
Anduril
4 x 18650
Qc3.0 charging capability
Claimed 1750m throw, my estimate is maybe more like 1650m
Under $250
I’m just a little worried spending $235 on this light, I may have wished I just kicked in another $100 and got the blf gt90. But then again, I think the sd90 will be significantly more “portable”, so maybe I’ll actually use it.
[US$249.00 30% OFF]Lumintop SD90 SBT90.2 7500LM High Lumen Strong 18650 Flashlight Type-C Rechargeable Long Range Powerful LED Torch For Outdoor Hunting Fishing Flashlight from Lights & Lighting on banggood https://banggood.app.link/PQKQg4aogfb
Absolutely, I’ve accepted the fact that no matter what lumen number the manufacturers post for sbt90.2, it’s going to be around 5000 Max. And that is completely fine with me. I know what 5000 lumens looks like, and when it’s throwing almost as far as my 1500 lumen osram, I’m 100% happy with 5000 lumens
