1*Luminus SST-40 LED / 6-mode / 1*21700/1*20700/1*18650 / 1380LM / cool white / USB rechargeable / IPX8 waterproof (2m underwater)
Intelligent temperature control system to maximise the lifespan of LED
360’ rotation to adjust beam angle for different applications
Power indicator function to know power level at anytime
Voltage: 3.7-4.2V
1m impact resistance
1700 lumens maximum output (1300 lumens spotlight + 400 lumens floodlight).
Compatible with 4 AA Ni-MH/Alkaline batteries (charging is prohibited).
Separately controlled dual switch for easy and fast operation.
Lockout function avoids accidental activation.
USB Type-C charging port with 2A fast charging, 3 hours for full charging.
60 degree tilt mechanism directs the beam where needed.
Made of quality plastics and aluminum, integrated die-casting for better heat dissipation and safety performance.
2m impact resistance
1*Luminus SST70 / 12-group/55-mode / 4000LM / pure white / 1*21700 / lanyard / IPX4 waterproof / intelligent temperature control
Voltage: 3.7-4.2V
Head diameter: 55mm
Intelligent temperature control: When the temperature of the flashlight reaches 55’C, the temperature control system will continuously automatically adjust the output current, and return to normal output when it is lower than 55’C
15 layers of heat dissipation, fully protect the internal circuit
12-group/55-mode:
The flashlight enters the flashing state, flash 1 time, then turn off the flashlight, select the first group; flash 2 times, turn off the flashlight, select the second group; flash 3 times, turn off the flashlight, select the third group; and so on.
Optional gear group: (where biking is a beacon, battery check is a battery capacity test, each flash represents 25%)
0.1% / 1% / 10% / 35% / 100% / strobe / biking / battery-check
100% / 35% / 10% / 1% / 0.1%
1% / 20% / 100% / strobe / biking / battery-check / sos
1% / 20% / 100%
100% / 20% / 1%
0.1% / 1% / 10% / 50% / strobe / biking / battery-check / sos
50% / 10% / 1% / 0.1%
100% / 20% / strobe
100%
Voltage: 3.7-4.2V
Head diameter: 55mm
12-group/55-mode:
1% / 20% / 100%
100% / 20% / 1%
100% / 20% / strobe
100%
Compatible with 1-4 21700 Li-ion battery (not included).
USB Type C charging and discharging interface, supports PD3.0/PD2.0, QC3.0/QC2.0 fast-charging protocols.
