XTAR PB2S question
6 posts / 0 new
Penny wise but ...
Penny wise but Lumen foolish's picture
Last seen: 6 months 1 week ago
XTAR PB2S question
Anyone know if this charger/ powerbank is compatible with Olight 18650 batteries? Specifically the batteries for the warrior mini, with both the pos & neg on the head of the battery, and the plastic ring around the button top.
I can't tell from online pics if the pos terminal in the Xtar will reach the Olight 18650 button top or if the plastic ring will interfere.
Reallllly specific question I know, but I know someone around here has the answer, you guys never let us down lol.
Thanks in advance!
Funtastic
Funtastic's picture
Last seen: 9 hours 31 min ago
If it doesn’t reach or the ring is an issue then use a neodymium magnetic maybe
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
TimMc
TimMc's picture
Last seen: 10 hours 40 min ago
The nipples on the PB2S at the top are just under 1mm long.
Does the Olight 18650 button top recess lower than that?
https://www.bmengineer.com/2019/09/xtar-pb2s.html
Penny wise but ...
Now that I took a better look at the battery (instead of going from memory) The button is actually taller than the ring. Must have confused this battery with another... I think the Xtar will work
ChrisGarrett
ChrisGarrett's picture
Last seen: 6 hours 14 min ago
You just buy some Samsung 50Es for cheap from Illumination and have 10Ah of capacity for hurricane season in a couple of months.
Chris
JagerLion
Last seen: 1 week 3 days ago
FYI the PB2S charges at 2A, which might be high for some uses. A 5W USB wall charger will limit the current if necessary and the PB2S won’t complain.
I shoot magic into the darkness!
