I asked Cindy from Wuben about 2 things: when will the light be available, and what is the price range!
I paste below her reply
When the link is available, I’ll post it here and udpate OP too!
:+1:
:+1:
Great review !
I think I like everything about this light except the 6500K part.
Do you know if they plan to release other tints or even better, an high CRI version ?
Also, have you tried to access the led ? How easy is it ?
Thanks for your words derfyled
Hum, I am not sure if it is a 6500K, I would say between 5000 and 6000K instead.
But tonight I can compare it with a cooler tint so that we can see that.
I wasn’t able to reach the LED. Yesterday I tried again but I don’t have the appropriate tools on hand to do it, so I may try it later.
I am not sure if the bezel is press fit or if it is glued because I wasn’t able to take it out. But I when I am able to do it, I’ll post it here
As far as I know, and looking to Wuben’s line of work, I wouldn’t count much on a High CRI version. If one can reach the led, it can be replaced by a 3535 footprint led, though!
TMaxxJJ did it on the Wuben H3 headlamp, here: ➿ FAST GROUP BUY ➿ WUBEN H3 Headlight 7-Modes OSRAM P8 Rotatable 2*AAA - #65 by TMaxxJJ
As promised I made some comparison beamshots between the Wuben D1 and some other flashlights in the range of 5000K to 6500K.
Here are the “results”:
From Left to Right, Vs:
Convoy S2+ XML2 U2-1A 65000K
Jaxman E3 Nichia 219C 5700K
Olight Warrior Mini SST40 ???K
Wuben D1 Osram P9 Cree XP-L HI 6500K (where th big toothpick is )
Wuben TO50R 4x Samsung LH351D 5000K
Wuben TO46R 3x XP-G3 5000K
FW3A 3x XP-L HI 3D 5000K
Convoy S6 3x Luxeon V 4000K
Convoy S2+ 3x Luxeon V2 3000K
It is definitely a bit cooler than some 5000K leds, but it is not as cool as the 6500K ones! It person, while taking this photo, it seemed “pure” white against the surface I was using!
The photo may be a bit tricky in some aspects but I guess they show more or less where the Wuben D1 is in terms of tint
Hope it helps
Where did you pick up the Luxeon V2 for your Convoy S2+ 3x Luxeon V2 3000K? The tint looks quite nice.
It is, indeed, a pleasant tint and it was a “grail” mod I wanted to do for a while (detailed here: What did you mod today? - #9723 by MascaratumB) .
I picked it at https://led4power.com/ last year. Some weeks ago I bought another, and it arrived today
Specific link: led4power
Thank you MascaratumB for this great comparison shot. Indeed, it does not seem to be 6500K but closer to 5000K. Still too cool for me but I’m a tint snob…
Something I really, really, really like about this light (and might have to buy it just because of this feature) is the lighted switch. I love being able to reach my flashlight on my night table or tent pocket in pitch dark. I hope Wuben will put this feature on all their new lights.
You’re welcome and I’m glad it helped perceiving where it “locates” itself in the spectrum
About the lighted switch, I get what you say, it is easier to locate the flashlight in the dark in a much better way! They also have it in other lights (E12R comes to mind, and others eventually).
As Lightbringer mentioned, I too preferred a different colour on the led indicator (red) but the fact is that it works as it is
The lighted switch is in my opinion the only thing missing on the T050R to make it perfect. I don’t know if you like it as much as I do but what a fantastic wall of light, pur high CRI joy…
Yup, probably one of the best lights I have too
That is a “beast” of a light! I am afraid of using it more giving it is almost a “premium” light, but whenever needed, it comes out of the “light-box”
And yes, an indicator LED could be good on it! Using a 21700, any parasitic drain would still make no harm on it!
BTW, I am not sure if Wuben uses the led indicator on the C3 and the C5 as well!
After checking Unheard’s thread reviewing the D1 I changed the information about the LED : it is a Cree XP-L HI 6500K instead of an Osram P8 or P9 as I initially suspected.
Thanks Unheard for the correct information
Very interested in this light, but would require me to swap in an 2700K 80+ CRI to be happy with it. Does disassembly seem feasible to do this?
So far I wasn’t able to remove the bezel and I am afraid that when I do that I will damage the host a little bit. Maybe I don’t have the proper tools for it or the skills, but it is really stuck :weary:
If or when I can do that I will post it here referring to the method to retrieve it!
Tried and failed, too. I fear it needs heat, but optics and electronic components are close to the bezel. I think I’ll live with it. It’s ok outside. Actually I’m happy about every single candle I can squeeze out of it.
Thanks for telling your experience Unheard
Yeah, I suspect some heat would be needed, despite I also think that it can be some pressure downside up! But for that I’d probably need to remove the driver and that may not turn good :weary:
I did it
I disassembled the head!
So, it is not glued, but pressed. I used the tools in the photo below.
The work-knife is quite tough so I used the “baton” method around bezel, starting on one side and making the diameter tryin to push the knife edge in. After a while, it started opening a gap and then I used the knife to press the bezel towards the top. And it poped-up!
Structure:
As Unheard has mentioned and confirmed before, this has a XP-L HI emitter.
As far as I can tell, a 3535 led seems to fit below, but careful if you want to try a XP-L HD, that has a larger dome.
Some notes:
Note that the bezel and the head have some marks because I used pliers and other tools before, unsuccessfully
Any questions, let me know
And good luck in case you folks try to disassemble it!
Well done
If ano scratches are visible, a sharpie/edding hopefully helps. Do you have an idea what LED you’ll reflow?
Thank you
Hum, the scratch on the optic does not interfere with the beam, and the scratches of the host…well, I’ll say it adds personality
As for the led to reflow I don’t have many options around me so a Luxeon V2 may be the candidate! I don’t know the tint yet :person_facepalming:
The optic sits really over the led, I can see the marks in mine, so it needs to be a carefull operation
And…done!
Luxeon V2 4000K on the board
It guess the beam is - structurally - the same, but the tint is obviously different
Here are some photos from it and from the driver.
BTW, the solder on the wires is quite tough, so if you’re going to replace the led, be ready for that!
Or maybe my soldering iron may is too weak, eventually
hello.
the battery can charge ony with 5V 1A charger? - because nowdays is hard to get. can i charge witg 5V 2.1 A or above charger?
thx
