Cool. Recent version of Anduril? Also does this use standard Carclo triple optics?
1. Does the USB-C port charge with a USB-C to USB-C cable?
2. Can the USB-C port be used as a power bank for your phone?
3. Is there Anti-Reflective coating on the lens in front of the triple-optic?
4. Are there pins/pads available so that the Anduril UI can be easily updated?
How much throw? What version of sst20 are available? Will it be available with xp-l hi? I would lume ro know if it can also NW charged with USB c to c with power delivery.
Will there be High CRI options? Lanyard hole? Always on standby led?
Good questions. It is the old version of Anduril, but you may update with interface and extra tool. Triple optics refer to the pic other member shared ahead.
1. Does the USB-C port charge with a USB-C to USB-C cable? It can be charge with that, but it will come with USB-C cable.
2. Can the USB-C port be used as a power bank for your phone? Not in this one, we try to make it simpler, to bring the price down, for power bank you may consider Wurkkos HD20.
3. Is there Anti-Reflective coating on the lens in front of the triple-optic? Yes, to protect the optic.
4. Are there pins/pads available so that the Anduril UI can be easily updated? We will leave the interface accessable, so you guys can update the UI according to your taste.
Really appreciate for all your questions.
Good suggestion, like that idea.
Beam distance will be around 200m. Maybe farther, you will see when you have one in hand. :money_mouth_face:
Lanyard hold in the tailcap, same as HD20. If you use Anduril UI, then you an set it on standby led. Regards CRI, you can choose according to your taste.
Is the optic made by Carclo, LedLink or another brand?
Carclo 10511 Frosted Narrow
http://www.carclo-optics.com/optic-10511
LedLink LL03LU-DMxxL
https://www.ledlink-optics.com/files/uploads/Multi%20Lens.pdf
http://www1.futureelectronics.com/doc/LEDLINK%20OPTICS/LL03LU-DMxxL.pdf
I only ask because it’s nice to be able to play around and swap the optic to produce different beam angles etc.
Wow I Will love It then,looking forward for some tests :sunglasses:
Yeeessss very nice :D Sounds like I'll get this light :D
Also, what is the driver based on? Just FET or is there a buck/boost/constant current circuit?
Looks nice, bigger version of the FC11.
The design isn’t finished it seems, but what do you expect will the weight with battery but without clip approximately be?
I’m curious as the IF25A with 4x SST20 is too heavy (ca. 166g with battery) for me in daily use, I prefer to use the FC11 though the SST20 4000K has a nicer light colour than the LH351D.
I prefer the UI of the FC11 to Anduril btw. With the IF25A I get too often into stepped ramping or other states that I didn’t want, I will make a general suggestion of this in another post of a different UI that I’m working on which largely avoids such issues.
The programming interface should be accessible so with this light it would be possible to flash Anduril 2 or other firmware I might do that because the only thing I miss in the FC11 UI is a battery voltage check so I guess Anduril 2 will do just fine. I too get sometimes stuck in settings with Anduril, even though I know the presses sometimes I miss a click and stuff…
Following
When will it be added to your website?
Buck driver?
Buck driver?
Want to know this too
10.0mm Narrow Spot Frosted TIR LED Lenses | Carclo Optics
10511 Carclo Lens - 3-Up Frosted Narrow Spot LED OpticLedLink LL03LU-DMxxL
http://www1.futureelectronics.com/doc/LEDLINK%20OPTICS/LL03LU-DMxxL.pdfI only ask because it’s nice to be able to play around and swap the optic to produce different beam angles etc.
Flatter than the above optics, therefore it is different. We try to make it as short as possible.
