Beam distance will be around 200m. Maybe farther, you will see when you have one in hand. :money_mouth_face:
Lanyard hold in the tailcap, same as HD20. If you use Anduril UI, then you an set it on standby led. Regards CRI, you can choose according to your taste.
Is the optic made by Carclo, LedLink or another brand?
Carclo 10511 Frosted Narrow
http://www.carclo-optics.com/optic-10511
LedLink LL03LU-DMxxL
https://www.ledlink-optics.com/files/uploads/Multi%20Lens.pdf
http://www1.futureelectronics.com/doc/LEDLINK%20OPTICS/LL03LU-DMxxL.pdf
I only ask because it’s nice to be able to play around and swap the optic to produce different beam angles etc.
Wow I Will love It then,looking forward for some tests :sunglasses:
We will leave the interface accessable, so you guys can update the UI according to your taste.
Yeeessss very nice :D Sounds like I'll get this light :D
Also, what is the driver based on? Just FET or is there a buck/boost/constant current circuit?
Looks nice, bigger version of the FC11.
The design isn’t finished it seems, but what do you expect will the weight with battery but without clip approximately be?
I’m curious as the IF25A with 4x SST20 is too heavy (ca. 166g with battery) for me in daily use, I prefer to use the FC11 though the SST20 4000K has a nicer light colour than the LH351D.
I prefer the UI of the FC11 to Anduril btw. With the IF25A I get too often into stepped ramping or other states that I didn’t want, I will make a general suggestion of this in another post of a different UI that I’m working on which largely avoids such issues.
The programming interface should be accessible so with this light it would be possible to flash Anduril 2 or other firmware I might do that because the only thing I miss in the FC11 UI is a battery voltage check so I guess Anduril 2 will do just fine. I too get sometimes stuck in settings with Anduril, even though I know the presses sometimes I miss a click and stuff…
Following
When will it be added to your website?
Buck driver?
Buck driver?
Want to know this too
10.0mm Narrow Spot Frosted TIR LED Lenses | Carclo Optics
10511 Carclo Lens - 3-Up Frosted Narrow Spot LED OpticLedLink LL03LU-DMxxL
http://www1.futureelectronics.com/doc/LEDLINK%20OPTICS/LL03LU-DMxxL.pdfI only ask because it’s nice to be able to play around and swap the optic to produce different beam angles etc.
Flatter than the above optics, therefore it is different. We try to make it as short as possible.
Wurkkos Terry:We will leave the interface accessable, so you guys can update the UI according to your taste.
Yeeessss very nice Sounds like I’ll get this light
FET, buck driver.
Wait, is it a buck+FET driver? Or is it a FET driver for the actual flashlight and a buck in the USB C charging circuit?
Any other improvement you would like to see on it?
It is buck driver.
Yes.
- Matte anodizing or raw aluminum.
- The pocket clip. Please use a one way deeep carry pocket clip. Deeper than the current design. Please refer to the new Noctigon KR4 clip:
Notice a few things:
- The clip reaches the end of the flashlight
- The starting / open end of the clip has a standoff that allows fabric to easily slide under when inserting it into the pocket.
- One direction clip. You already have a second mounting groove near the head for reversibility, don’t make a redundant and bulky clip.
- Increase the opening of the bezel so that it’s not blocking any light from the optic. Looks like it needs an extra 1-2mm or so in the pic below.
- Make 100% sure this optic is compatible / swappable with Carclo 105xx optics.
Even brass or copper edition would be great, I second the use of standard size optics so we Can use turboglow Inside It
The only things “missing” is IMO an/a few AUX LED’s Other than the powerbank functionality this light seems to have everything I want in a flashlight
