FREEME ✌ LUMINTOP FWAA Andúril 2 14500 Flashlight Deals - CL2 Bundle Deal
I’m personally not a fan of the etching in the slightest. But I suppose I could strip the ano from the bezel on my own if we can’t get it without.
interested in nichia 5.000k + 4.000k with pocket clip.
thanks, freeme :beer:
i would prefer anduril 1 and would appreciate nimh support.
I would too. Would really like to see this as a single LED, AA and 14500 compatible, and something stainless/ti
Been out of the scene for a while, so there may be something similar with anduril already made?
Nope, Anduril requires lithium cells.
Hmm, to be more precise, Andúril runs on MCUs that require voltage above alkaline single cell. 2 or 3 (not sure) alkalines, CR123A, and such can do it. Also, gchart has a sofirn light (SP10S?) running Andúril with AA alkaline/nimh - but that’s a bit complicated, with the MCU’s voltage being boosted.
Interested in 219c 4000k, with clip, no etching.
Just reporting what I’ve seen posted about Andruil, Toykeeper has said multiple times it requires lithium cells. It might depend on the version of Andruil, not too sure.
Interested…
Anduril doesn’t care about the power supply, it never did. It’s just the MCU that needs at least 2 V. You could easily boost the voltage up.
A boost circuit powering the MCU seems like a recipe for high parasitic drain. But I could be wrong. I would love to see any ramping UI running whatever MCU necessary for a NiMH cell to work with low parasitic.
Bare bones, watered down Anduril Ramping UI
From off:
1H moon (pause for 1.5-2s then continue ramping)
1C memory
2C high (current chosen which naturally stabilizes at ~55-60C tail-standing w/o any airflow)
From on
1H ramp up
2H ramp down
1C off
2C turbo (timed step down for simplicity - another 2C returns to previous mode - manual restart if desired)
No other fluff. It’s an AA light, so no blinkies of any kind make sense. No aux LEDs draining the small cell. I can’t see how this UI couldn’t be written to fit within even the smallest of MCUs
Please add me to the list,i want one either way it comes out sins sofirn is taking forever with the sp10 anduril
It's here!
How do we buy one now, never having been part of a group buy here?
I will put your name down on our list later. Deal information will be forwarded to all when preorder starts in about 1-2 weeks time.
Neal will discuss with LT.
Will be interesting to see how they fit a FET+7+1 on a single sided 17(?) mm driver(!). Stacked 7135s? Or the specs are wrong…
Seeing this image, it seems that the FWAA will be even shorter (although larger in diameter) than the DQG Slim Ti AA :o
Interested
Interested, SST20 4000k if it exists, otherwise 219c 4000 or 5000k
Taller than DQG @74.1mm.
