Best High Capacity 21700
69 posts / 0 new
Sirstinky
Last seen: 2 hours 20 min ago
So we all know who makes the best 4000/4200 mAh 21700, but what about over 4200 mAh? Who makes the best 5000 mAh 15-20 amp CDR 21700?
I’m looking at Shockli 4550 mAh currently since the Samsung 50G and 50S are AWOL, amd forget about the Vapcell T50 becoming available anytime soon. Anyone used those Shockli?
zoulas
zoulas's picture
Last seen: 47 min 31 sec ago
There are a bunch of 5000mah out there but as you know capacity comes at the cost of drain.
Sirstinky
True. I know you really can’t ask a 5 Ah cell to realistically give 15-20 amps, but for currently available cells, which one is the best?
ChrisGarrett
ChrisGarrett's picture
Last seen: 7 hours 42 min ago
I bought four Samsung 50Es for an Xtar PBS2 power bank.
I went with capacity over current handling.
Chris
Kos70
Last seen: 6 hours 12 min ago
Samsung INR21700-50S I would look in their direction …
gchart
gchart's picture
Last seen: 15 min 57 sec ago
If you’re not looking for super high-drain applications, the Sofirn 5000 mAh is pretty decent. There’s a test from HKJ here and another test here. It’s reported to be a Lishen LR2170SD rewrap, which may be available at other places.
Funtastic
Funtastic's picture
Last seen: 3 hours 19 min ago
Yes, the Lishen LR2170SD is excellent, although the positive terminal caves much easier than a Samsung.
They are available also from the 18650batterystore.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
gchart
gchart's picture
I was going to mention 18650BatteryStore but they seem to be sold out at the moment. Only $5 though.
Superstocker
Superstocker's picture
Last seen: 47 min 36 sec ago
Molicel m50a is a solid choice too.
mbp
Last seen: 1 day 6 hours ago
I have some Tesla 21700s on the way from techdirectclub.com. Advertised as 5000mah 15A continuous discharge, identical to 50G, hard to beat that IF (big if) it measures up.
Funtastic
Funtastic's picture
Datasheet I found was 10A, this cell is also advertised at 15A, but 15A felt too much.
See below at my load test at 5 and 10A of the Lishen LR2170SD (black), Tesla (red), 50E (blue). Ignore the red circle, had clicked there while saving the image.
Dips lower since it has higher resistance. These Tesla’s are from Tesla modules so they aren’t new, none of them are.
Sirstinky
Nice. I think those are the Sanyo ncr21700b right? Indeed, they are rated at 15 A CDR, but will be happiest under that.
Sirstinky
That Lishen cell is in n a lot of wrappers I reckon. Seems to have good performance for the price though. It’s seems like 10-15 A is the max for 5000 mah. The Sofirn, M50A, and Samsung 50G or Vapcell G50 are on the list…
Funtastic
Funtastic's picture
Wasn’t sure what they are, but Mooch tested them here
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 4 days 8 hours ago
I agree, Sofirn's 21700 5000mAh battery (rewrapped Lishen LR2170SD) is a very decent choice for a high capacity battery. As long as you do not need insane power (e.g. any SBT90.2 flashlight) you should be fine with that battery. As an alternative, I use Sanyo/Panasonic NCR21700A ("Tesla battery"), Samsung 50E and Samsung 50G with more or less comparable results in terms of capacity. If you need the best of both worlds, try to get Samsung's 50S (or Vapcell T50). Unfortunately, it is sold out and it does not seem to become available again anytime soon.
By the way, NKON still has some very decent prices for 21700 batteries. Maybe an interesting option for members from the EU...
https://eu.nkon.nl/rechargeable/li-ion/21700-20700-size/samsung-inr21700-50g-clear.html
https://eu.nkon.nl/rechargeable/li-ion/21700-20700-size/samsung-inr21700-30t-3000mah-35a-clear-wrap.html
https://eu.nkon.nl/rechargeable/li-ion/21700-20700-size/lg-inr21700-m50-4850mah-7-3a-clear.html
https://eu.nkon.nl/rechargeable/li-ion/21700-20700-size/samsung-inr21700-48g-4800mah-35a.html
Sirstinky
Lux-Perpetua wrote:
I agree, Sofirn’s 21700 5000mAh battery (rewrapped Lishen LR2170SD) is a very decent choice for a high capacity battery. As long as you do not need insane power (e.g. any SBT90.2 flashlight) you should be fine with that battery. As an alternative, I use Sanyo/Panasonic NCR21700A (“Tesla battery”), Samsung 50E and Samsung 50G with more or less comparable results in terms of capacity. If you need the best of both worlds, try to get Samsung’s 50S (or Vapcell T50). Unfortunately, it is sold out and it does not seem to become available again anytime soon.
By the way, NKON still has some very decent prices for 21700 batteries. Maybe an interesting option for members from the EU…
Thanks! I found some Vapcell G50’s on AE, but Samsung 50S are nowhere to be found. Unfortunately I’m in the US and Nkon doesn’t ship here.
Havok
Last seen: 2 weeks 4 days ago
18650batterystore.com sells 50G’s rewrapped as their in house Epoch brand.
I bought three, and all the cans underneath are stamped 50G.
Enderman
Enderman's picture
Last seen: 4 days 23 hours ago
#1) Vapcell T50 = Samsung 50S
#2) Vapcell G50 = Samsung 50G = Epoch 21700
#3) Tesla 21700
#4) Molicell M50A
#5) Samsung 50E2/3
Is this the correct order of performance/rewraps?
CR888
Last seen: 2 hours 32 min ago
Subbed to this thread I bought a copper Lumintop fw21 ×9l which has sbt90.2 6500lm that requires a 30A cell. I have some Samsung 50E’s in the mail for other lights & I think they are 15/25A 15A cobtinuous. I’m looking for 30A with the most mAh.
CR888
Sirstinky
50E is maybe 10A at the upper limit (read:safe). For the highest capacity and power-handling you want like a P42A or if you can find it 40T. F9r all out power, 30T.
Sirstinky
Awesome, how do they perform?
Havok
They’ve been great. I run ‘em to about 3.5V at 5A all the time.
CR888
I was going to ask who makes the P42 21700’s but I did some searching and found Vapecell had P42 which they claim are re-wrapped Molicell 30A 4200mAh cells. I got 2 for about $15au each. I’ve only spent around $200 in 2 days on damn batteries. Facepalm Thanks. Now I only need 8× 18650’s & I’m done, then all my lights will have cells.
CR888
Sirstinky
Nice. I think you’ll be happy with the P42A. More runtime and nearly identical performance to the 40T.
georgeorwell
IDK. I’m just using a noname one from Aliexpress… hehe
zoulas
zoulas's picture
P42A is excellent. I switched when the VTC6A became unavailable. At about $5 / each its quite a battery.
CR888
Yeah I think so, I’m not that great at working out my lights exact requirements. I mean there ain’t no point having a 35A low mAh cell to be used in a light that will maximum draw 10A. But some of these new single cell sbt90.2 really suck amps, Lumintop recconends a cell that is constant current 30A for the fw21×9l. Choosing cells for short tube lights is a little tricky. Like say the A/lux EA01s 4xXHP50.2 11k lm. Now what 26350 is gonna power that? While not a real useful sustainable light, it’d be a fun ‘wow’ light.
CR888
Sirstinky
The 26350 only delivers maybe 10 amps. Turbo in the ft02s (probably same driver) is a bonafide 30+ amps (I tested it), so it won’t reach max brightness. Might get 3000 lumens out of it.
Tom E
Tom E's picture
Last seen: 3 hours 46 min ago
Dunno why everyone is wasting their time - look at Enderman's post - the best 21700 cell is the Vapcell T50 which is a Samsung 50S.
Not say'n they are easy to get, but the title of this thread has only one answer.
Sirstinky
Tom E wrote:
Dunno why everyone is wasting their time – look at Enderman’s post - the best 21700 cell is the Vapcell T50 which is a Samsung 50S.
Not say’n they are easy to get, but the title of this thread has only one answer.
Part of the reason I created this post is because those are nowhere to be found and was looking for a substitute. The T50 were a limited run for Vapcell and currently they’re about impossible to get. Samsung 50S are also nowhere to be found. The 50G is almost as good and can still be found (at least for now).
JaredM
JaredM's picture
Last seen: 3 hours 34 min ago
I wonder how the Tesla’s stack up charged to 4.1V. I’d bet they don’t charge beyond that in the cars..
EDIT: Just checked the mail. They arrived. I’ll do some tests to see how balanced they are.
