RD6018W customer review
The original idea is a power supply from ready-made independent parts.
Frequently asked questions:
Can I use your power supplies to charge battery?
yes, for RD series, please use the battery charging terminals, it has protection function, for DPS series power supply, you must check the wiring before turn on the output, it has no reverse protection.
RD6018 customer feedback
great seller recommend, packed great
https://www.aliexpress.com/item/1005001488070904.html
hello, when you get part of your order, do not worry, you can check your order to see if there are multiple packages to send your order, or you can contact us to let us help you, no need to make dispute immediately
it should soon , it will be 618, there is a sale promotion
