You changed the title to tester wanted, so you have prototypes ready or do you need testing of custom firmware? I’d be interested, I have a USBasp and so can program firmware for testing.
I would love to test that light. It is almost the FC11 21700 I’ve been dreaming of… I’d be happy to make a video review for it if thats helpful as well.
Three things though I’d love to see changed…
Please offer it with the same UI that you had with your FC11. Part of the beauty of your products so far has been that I can use them in the real world. If you hand a random person an andruil light you have to babysit them and then explain why you are a crazy person with a crazy light.
The double sided clip isn’t really necessary. Nobody could put that thing on a hat so it doesn’t make sense. I’d rather have a single direction clip (preferably with screws to add/remove) but its still a decent clip so not a huge deal.
The button is a big step backwards from the button you use on your other lights (FC11, TS30, etc). That looks like the button that Sofirn uses on the SF47T, SP33, etc and that button is a huge step backwards. It doesn’t feel nearly as nice, it is so much easier to hit accidentally. I’d really like to keep the fantastic button you have been using.
Also I’d love to see a single emitter version. I just want a 21700 fc11…. Pretty please
I agree! If one could choose between Anduril and a simpler UI that would be great!
I don’t quite agree with that… I was happy it was a button like this instead of the regular more rubber-y button. I have a Sofirn SP31 UV and I like the button more than on my other Sofirn lights, more “tactile” feeling or something… But you are correct, it is easier to trigger by mistake…
I’m not a fan either, of the big round button, with a bezel, in the middle of a square recess, just purely from an aesthetic standpoint. It could be more elegant. And why isn’t that bezel blue, which is sort of Wurkkos trademark?
The protruding metal button is also easier to inadvertently trip, compared to the silicone button found on the the lights Sofirn produces, which also provides sharper tactile, as well as some audible, feedback. The metal buttons aren’t horrible, but if this one is like the one on the SP35, the tolerances aren’t tight enough to prevent a rocking/sticky action if not pressed squarely, which detracts from the experience. The smaller metal button on the SP31/32 has less surface area, so it’s not as bad in that regard.
And, if this light is going to use Anduril, it will miss out on the illuminated button options.
I’d switch to the silicone button, and simplify/clean up the design of the head in that area. The FC11/SC31B/Pro/IF25/EC0x/etc. have already shown the way in that respect.
Hi Outdoor_Matters, really like your suggestions, you just shout out my voice, I personally like the UI of FC11, but we make TS21 with Anduril UI, just would like to please most BLFers here, we will try to have a simpler version in future. Thanks for your precious suggestions.
The UI of the Sofirn SP35 I think is nearly a perfect balance of featured yet simple. The only detail I wish was different are the shortcuts out of turbo. I like double for returning to memorized mode and one for off, like Anduril 1. The SP35 double goes to moon and single back down to memorized. A delayed second click is needed for off — which is why this isn’t so nice.
