Keeppower 14500 1100mAh P1450C3 (Black) 2020
Official specifications:
Voltage: 3.70V
Rated capacity: 1100mAh
Minimum Capacity: 1000mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
Standard charge current: 500mA
Maximum constant discharge current: 2A
Protected high capacity 14500 LiIon batteries from Keeppower
The two cells tracks fairly well and are not high current cells.
Conclusion
These cells looks like good high capacity 14500 cells.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
