Sunwayman V11r, stock XM-L Cool White
debating whether to mod to
2700k LH351d
or sw45k…
2700k LH351d
or sw45k…
Definitely sliced 2700k lh351d. Can recommend it.
thank for your thoughts
I agree sliced 2700k lh351d is very nice and warm
glad you enjoy it also
the middle light is the shaved LH351d 2700k:
l-r LH351d 2700k shaved, 219b 4500k, xp-e2 green:
Got my Pioneman K18 and L80 with battery and charger set. Ordered from their offical store in Ali 2 weeks ago.
Just got my first B158B ever in the mail today and I hastily slopped it together with a Osram Black Flat S shorting out (intentionally) and therefor DD through the stock driver and a few bypasses. 319kcd! Not bad for 10minutes of modding.
The light I got from AE and it is a super clean and high quality host. Ano is beautiful with no markings and threads are smooooth. Everything is beefy and the lens was immaculate. Nicely packaged with egg crate foam padding in a sturdy but plain box.
When I get more time I’ll black out the internals, use a proper centering ring, adjust the pill so that 100% zoom is at the end of the travel, and start planning how I’m going to get a DIY collar in there. Pics will follow
I got an order from Kaidomain. An S2 host, some 2700k SST-20s, and various centering rings. They screwed up and sent me a bag of 5050 centering rings in place of 3030…
Lumintop EDC AA Ti.
I know I am late to the party, but I finally found some time to plan a few thrower builds.
Simon was kind enough to send me:
KW CSLNM1.TG 6N-ebxD46-15 6000-6500K
From payment to delivery in my mailbox, it only took 11 days. What others say about Simon’s Convoy store is 100% true, couldn’t be more happy.
Now all I need is a decent driver for this build.
Novatac Spa with Steel Bezel, unlocked and fully programmable. LED is a very nice SSC P4, 94 lumens max, 0.08 lumens minimum. Tactical momentary enabled.
sw45k, nw xml2, ssc P4:
Nice light, Jon. Any plan for LED swap for more output?
thank you
I would like to change the LED, but have never tried to open a Novatac, so Im waiting for a moment of inspiration.
Ive had some failures to open a couple of other lights recently, an Eagletac D25a Ti, and a Nitecore Sens Mini. The mini is destroyed. The ET still works, but still has the ugly low CRI LED…
Do you have a suggestion how to defeat Novatac glue, do you use heat?
I had another Novatac w black bezel, that after modding gives 250 lumens. I was quite happy with that. The light now belongs to one of my adult children. So I glad to have found another.
Here is an old thread about Novatacs
it includes your triple, that I find inspiring:
I believe you have the D25a Ti version with the brass pill inside. These lights have a simple construction consisting of a brass pill with threads on both sides for both the bezel and the battery tube.
Eagletac used threadlocker to fasten the pill to the Titanium bezel. I believe they did this to reduce the chance of the bezel accidentally unscrewing when trying to remove the battery tube.
On mine, I was able to remove the bezel from the pill for an LED swap with a bit of muscle-power. I wrapped grey 3M safety walk tape around the bezel for grip and to protect it and did the same with the brass threads. That wasn’t quite enough so I ended up using pliers on top of the tape on the threads. Then just unscrew. It came off with a bit of work, but no heat was needed. The brass threads where the battery tube screws in got a little beat up from the pliers, but they still work completely fine and the exterior of the light was not damaged.
Incidentally, the earlier model of D25 Ti is easier to mod. It has no pill and no glue. However, it also has less smooth action when unscrewing the bezel due to Ti on Ti. And more importantly, the driver is not as good as the later model D25a Ti. It loses access to intermediate modes when run on 14500.
Just in the last week I modded both versions of D25a Ti
congratulations
post pics
the brass pill on my 2014 D25a Ti got crushed into an oval shape by the vise grips I used. It was not pretty.
There is not going to be any more modding on this light,
pros
it still works. It is a very nice host, thinnest AA I own, with a great clip.
I do not own 14500, I only use AA Eneloop, all the modes work
cons
the tailswitch on mine is very difficult to activate, and once on, it will switch modes at the slightest touch…
I do not love using low cri, but, the LED is useful for beam photo comparisons…
there is banding in some photos, that resembles PWM
So far I have opened 4 Novatacs with black bezel, it’s not hard at all.
Just push the bezel into something rubbery (floor mat, sandals, shoes, car’s tyre) and twist it counter clockwise to unscrew the bezel.
The challenge will be removing the old LED which was glued into the host and building a base for placing your triple MCPCB.
Got a new to me Alpha today. Goes great with the rest of the family.
congrats!
Very Nice Family Photo
Jason really knows what hes doing.
would like to see a beam lineup too
Thanks Jon, he really does know how to make a quality product imo. All his lights amaze me every time I use one.
I plan to get some beam shots once the cells finish charging.
I’ve got both bodies for the Alpha also but prefer the way the short body just feels in the hand.
This flashlight looks like its missing the front third of it.
