Where do you put discount code in.
Dang. The batteries were not listed when I ordered.
if u buy the battery with order does he ship the battery inside the light or ?
Ordered each one of the nichia flavors and 2 SST20’s since the XPG3 is sold out. Also 2 14500’s.
The wait begins…
Thanks! Ordered Nichia 4000K with a 14500 battery.
Order placed for one Nichia 219C 4000K with a couple 14500 Vapcells.
Battery will be shipped together with your FWAA. Do leave a note if you wish to keep the battery inside the light.
It’s the opposite. Output on turbo will be higher and the light will get hotter and step down sooner.
If ordering H10s from the Vapcell store on Ali, be careful. There are 3 versions of 14500 batteries that are the same color (purple) I got absorbed in getting the lowest price (there are different venders) and didn’t notice until after they shipped. I ordered 4 C8 2A 14500 batteries I have no use for. Ouch. Had to reorder H10s.
Left a few more.
Ordered 1 with Nichia 4000K !
Thanks freeme and Neal
I have unprotected button top Vapcell H10 and unprotected flat top Shockli H10 too, and now I ordered 1 H10 flat top to see the differences between these in terms of height!
So…did anyone other than treellama get a shipping refund?
I ordered other stuff above 50€ and got free shipping, so I can’t tell much about that :zipper_mouth_face:
Ordered one Nichia 4000K.
I was wondering the same thing, Illum lists the minimum capacity which has a 100mAh difference between the 3A and 10A cells. Not sure why Vapcell carries both since 100mAh probably translates into less than a 5 min difference in runtimes
I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
Ordered one with SST20.
Any chance there will be a stainless steel bezel available for these? I’d gladly add one of those to my order.
I purchased the Vapcell h10 button top. They are 49.4mm. Will they fit the fwaa.
Not sure where you purchased from but Illumn shows both the flat top and button top have a length of 49.4mm. I don’t think that can be right.
I purchased from Illumn. And I saw that aswell
I’m trying to find out from lumintop if the button top will work. I believe they will as they are listed at 1.1mm under the stated battery size.
