RD6018 RD6018W 60V 18A power supply is published
RD6018W customer feedback
All perfectly. The box comes with a complete set of wires and fasteners, an outlet and a switch.
https://www.aliexpress.com/item/1005001488070904.html
all perfectly.
RD6018W feedback
The converter with the housing came to me in good condition and without any additional charges. visually everything is really good quality and it looks like everything will be OK. I am very happy with my purchase
RD6018W customer review
this is necessary for everyone who works with electronics, has a pretty good monitoring, very good product.
I ordered a complete set: RD6018W with an S800 case and an S-1000-68 power supply and assembled it. Everything works fine. The packaging is branded, especially the RD6018W module, so iPhones are packed.
RD6018W feedback
Well packed. I want to use it with a 1000VA toroidal transformer 50VAC (70VDC) to have less noise, it fits perfectly in S800 case.Nice soft buttons. WiFi tested and works good. Battery charge datalogger is ok, but it only exports to Excel.
Very nice packaging. Works great.
RD6018W feedback
Everything is at the highest level. Delivery to Belarus took 15 days. Packed soundly.
RD6018W feedback
The best power supply dc/dc DIY, nice product 100%
Frequently asked questions:
Can I use your power supplies to charge battery?
yes, for RD series, please use the battery charging terminals, it has protection function, for DPS series power supply, you must check the wiring before turn on the output, it has no reverse protection.
perfect product, matches seller's description
RD6018 customer feedback
great seller recommend, packed great
hello, when you get part of your order, do not worry, you can check your order to see if there are multiple packages to send your order, or you can contact us to let us help you, no need to make dispute immediately
RD6018W feedback
The product is really nice, thank you very much about the seller, the product is wonderfully packaged but it was removed and checked by the customs on the way to Turkey
for RD series, there is a option called ”Boot Pow”,which means when you power on the device,the output will be turned on automatically,but it only applies on the normal red terminal,the battery charging terminal doesn't have this function for saftey reason
https://www.aliexpress.com/item/1005002185722889.html
it should soon , it will be 618, there is a sale promotion
received an order! packed perfectly, arrived pretty quickly. everything works great!
RD6018W feedback
IML delivery in 3 days (during the May holidays), packed perfectly. The packaging of the module itself pleased me. I will check for heating in stress mode, pulsations, and the accuracy of the readout meters. look for Crazy_Geeks on YouTube
RD6018W feedback
Arrive faster than expected, well packaged and operates as expected. Took serveral days before it shipped and tracking didn't work but it arrived in less than 2 weeks from order so very happy.
hello, I need to say it once again, when using DPS or DPH series power supply to charge battery, please follow this: 1. check the if the connection is right, 2. set the suitable voltage and current, 3. turn on the output. the connection is very important
but for RD series power supply, as long as you use the battery charging terminal, it has no problem, even though you connect the battery in the wrong way, it will use icon to show you that the battery is not connected and will not output
DPS5020:https://www.aliexpress.com/item/32821185351.html
