You’ve got two complete cycles (6 clicks) from off before hitting the blinkies, but at any point before the 7th click, just soft press and you go back to the start.
Moon mode is modulated. Sinewave, approx. 11ms phase, about 90 Hz. That’s what it looks like. Can’t measure mid already. Opple LM3 reads 4000 Hz, but the data looks suspicious. I think it is much more. That’s for the 2015 D25A, not sure if they have changed anything.
The set of blinkies is strange. Wish it wasn’t there.
thanks
yes, two cycles of LMH leads to 7 different blinkies :person_facepalming:
(on mine, a brief tap, not a click, advances modes)
and yes, I found a long press goes back to low…
thanks, yes, the 2015 has unballanced looking knurling…
the frequency of the circuit oscillations do seem quite fast… my camera can see them, but I almost cannot see them, I have to wave my hand really fast…
people confuse it with PWM, but I beliece ET is correct to call it Constant Current… or my unofficial names for it… Constant Flicker… or Constant Ripple… LOL
I wish I could change the LED, but 2014 are not moddable
I think 2013 was the last year for the moddable design, with removable bezel…
I had mine in the freezer because thermal expansion of brass is greater. Could have made a difference, not sure. Getting that pill out was extremly difficult, but I had to try it.
I might be completely wrong, but in theory heat lets brass expanding more than titanium. You’re weakening red threadlocker on the other hand. Not sure.
In the end, it was brute force and luck that the pill didn’t broke I fear.
The brass pill in the newer version is not press-fit. It’s screwed in with a small amount of glue. I muscled mine out with some 3M grey grip tape and pliers.
I don’t have a D25A, only the C versions (which open no problem from the bezel), but, if the heat or the cold don’t work, acetone is worth a try.
This is how I opened my old Bitz. Boiling the head for hours did not work, freezing it for days neither.
Anyway, I can assure you that acetone will not attack aluminum, titanium or bronze. However, beware the plastic component of the driver.
Happy modding!
