It’s the opposite. Output on turbo will be higher and the light will get hotter and step down sooner.
If ordering H10s from the Vapcell store on Ali, be careful. There are 3 versions of 14500 batteries that are the same color (purple) I got absorbed in getting the lowest price (there are different venders) and didn’t notice until after they shipped. I ordered 4 C8 2A 14500 batteries I have no use for. Ouch. Had to reorder H10s.
Ordered 1 with Nichia 4000K !
Thanks freeme and Neal
I have unprotected button top Vapcell H10 and unprotected flat top Shockli H10 too, and now I ordered 1 H10 flat top to see the differences between these in terms of height!
Agro
(Agro)
April 20, 2021, 9:12am
364
So…did anyone other than treellama get a shipping refund?
I ordered other stuff above 50€ and got free shipping, so I can’t tell much about that :zipper_mouth_face:
hunter1
(hunter1)
April 20, 2021, 10:59am
366
Ordered one Nichia 4000K.
supreme
(supreme)
April 20, 2021, 4:15pm
367
Notmyrealname:
I saw those when I was looking. It’s goofy as heck that they even offer the other cells. To go from 10A to a measly 3A you gain just 50mA and save 42 cents per cell. But why would buy that when you could get just 800mAh and only 2A to save a wopping 12 cents per cell!
Unless I’m missing something, it’s bad marketing that they even offer and put their name on anything but the best. Price an capacity weirdness aside, makes much less sense that the bottom of the barrel ones are the same color as the best, when the best they do offer is in fact one of the very best you can buy from any brand?! At least that I’ve seen.
Craig from Illumn says they’ll get stock in three weeks, so I’ll just wait it out and then wait another week.
I was wondering the same thing, Illum lists the minimum capacity which has a 100mAh difference between the 3A and 10A cells. Not sure why Vapcell carries both since 100mAh probably translates into less than a 5 min difference in runtimes
Jimo
(Jimo)
April 20, 2021, 4:25pm
368
I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
asdqqq
(asdqqq)
April 20, 2021, 4:35pm
369
Ordered one with SST20.
Any chance there will be a stainless steel bezel available for these? I’d gladly add one of those to my order.
Jimo
(Jimo)
April 20, 2021, 5:00pm
370
I purchased the Vapcell h10 button top. They are 49.4mm. Will they fit the fwaa.
wolfstyle
(wolfstyle)
April 20, 2021, 5:03pm
371
Not sure where you purchased from but Illumn shows both the flat top and button top have a length of 49.4mm. I don’t think that can be right.
Jimo
(Jimo)
April 20, 2021, 5:04pm
372
I purchased from Illumn. And I saw that aswell
Jimo
(Jimo)
April 20, 2021, 5:18pm
373
I’m trying to find out from lumintop if the button top will work. I believe they will as they are listed at 1.1mm under the stated battery size.
freeme
(youtube.com/@1thedeals)
April 20, 2021, 5:25pm
374
My flat top is 48.8mm.
[quote=wolfstyle]
[/quote]
vit55
(vit55)
April 20, 2021, 7:43pm
375
Thanks Freeme purchased sst20 4000k
TIFisher
(TIFisher)
April 20, 2021, 8:18pm
376
Order complete Nichia 4000k. Thank you.
Firelight2
(Firelight2)
April 20, 2021, 8:28pm
377
Osram:
- Very intense and small hotspot. Lots of throw.
- Best choice of emitter for longer ranges.
- Pretty poor up close due to small size of hotspot and overall low lumens.
- Cool white tint - looks good at full power. Looks a bit greenish and ugly at lower power.
SST-20:
- Less intense beam. Less throw than Osram, with considerably wider beam.
- Good for close-medium range.
- Adequate for up close use, due to wider beam. But still inferior for close range compared larger emitters such as LH351D.
- Available in very high-CRI. Renders colors very well.
Ugly greenish tint at lower power settings. More green than Osram.
4everAwake
(4everAwake)
April 20, 2021, 8:33pm
378
I’m interested - SST 4000k version
Agro
(Agro)
April 20, 2021, 9:13pm
379
Firelight2:
Osram:
SST-20:
I believe in this light SST-20 won’t work well at medium range, only up close.
Jimo
(Jimo)
April 20, 2021, 9:44pm
380
What do you consider the perfect led
