Left a few more.
Ordered 1 with Nichia 4000K !
Thanks freeme and Neal
I have unprotected button top Vapcell H10 and unprotected flat top Shockli H10 too, and now I ordered 1 H10 flat top to see the differences between these in terms of height!
So…did anyone other than treellama get a shipping refund?
I ordered other stuff above 50€ and got free shipping, so I can’t tell much about that :zipper_mouth_face:
Ordered one Nichia 4000K.
I was wondering the same thing, Illum lists the minimum capacity which has a 100mAh difference between the 3A and 10A cells. Not sure why Vapcell carries both since 100mAh probably translates into less than a 5 min difference in runtimes
I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
Ordered one with SST20.
Any chance there will be a stainless steel bezel available for these? I’d gladly add one of those to my order.
I purchased the Vapcell h10 button top. They are 49.4mm. Will they fit the fwaa.
Not sure where you purchased from but Illumn shows both the flat top and button top have a length of 49.4mm. I don’t think that can be right.
I purchased from Illumn. And I saw that aswell
I’m trying to find out from lumintop if the button top will work. I believe they will as they are listed at 1.1mm under the stated battery size.
My flat top is 48.8mm. [quote=wolfstyle]
[/quote]
Thanks Freeme purchased sst20 4000k
Order complete Nichia 4000k. Thank you.
Osram:
- Very intense and small hotspot. Lots of throw.
- Best choice of emitter for longer ranges.
- Pretty poor up close due to small size of hotspot and overall low lumens.
- Cool white tint - looks good at full power. Looks a bit greenish and ugly at lower power.
- Low CRI
SST-20:
- Less intense beam. Less throw than Osram, with considerably wider beam.
- Good for close-medium range.
- Adequate for up close use, due to wider beam. But still inferior for close range compared larger emitters such as LH351D.
- Available in very high-CRI. Renders colors very well.
- Ugly greenish tint at lower power settings. More green than Osram.
I’m interested - SST 4000k version
Jimo:I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
Osram:
- Low CRI
SST-20:
I believe in this light SST-20 won’t work well at medium range, only up close.
What do you consider the perfect led
Ok you lost me
