I was wondering the same thing, Illum lists the minimum capacity which has a 100mAh difference between the 3A and 10A cells. Not sure why Vapcell carries both since 100mAh probably translates into less than a 5 min difference in runtimes
I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
Ordered one with SST20.
Any chance there will be a stainless steel bezel available for these? I’d gladly add one of those to my order.
I purchased the Vapcell h10 button top. They are 49.4mm. Will they fit the fwaa.
Not sure where you purchased from but Illumn shows both the flat top and button top have a length of 49.4mm. I don’t think that can be right.
I purchased from Illumn. And I saw that aswell
I’m trying to find out from lumintop if the button top will work. I believe they will as they are listed at 1.1mm under the stated battery size.
My flat top is 48.8mm. [quote=wolfstyle]
[/quote]
Thanks Freeme purchased sst20 4000k
Order complete Nichia 4000k. Thank you.
Osram:
- Very intense and small hotspot. Lots of throw.
- Best choice of emitter for longer ranges.
- Pretty poor up close due to small size of hotspot and overall low lumens.
- Cool white tint - looks good at full power. Looks a bit greenish and ugly at lower power.
- Low CRI
SST-20:
- Less intense beam. Less throw than Osram, with considerably wider beam.
- Good for close-medium range.
- Adequate for up close use, due to wider beam. But still inferior for close range compared larger emitters such as LH351D.
- Available in very high-CRI. Renders colors very well.
- Ugly greenish tint at lower power settings. More green than Osram.
I’m interested - SST 4000k version
Jimo:I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
Osram:
- Low CRI
SST-20:
I believe in this light SST-20 won’t work well at medium range, only up close.
What do you consider the perfect led
Ok you lost me
Ordered 1 Nichia 3000K & 1 Nichia 4000K Thanks freeme
For raw impressive output, I’ve still yet to find anything better than XPL-HI for small triples. XPL-HI offers nearly as many lumens as LH351D, with much more intensity, neutral white color temperature, and excellent rosy tints. Also due to its higher forward voltage it tends to run cooler in these tiny hotrods than other LEDs like SST-20 or Nichia 219c.
If you want to impress your friends, XPL-HI tends to be the most impressive.
Unfortunately, XPL-HI does not come in high-CRI. My current EDC is a modified DQG Tiny 18650 IV running Anduril with three high-CRI Nichia 219C as emitters.
This setup is quite a bit lower output than XPL-HI, but I like the tint, color temperature and CRI.
Thanks for the info I appreciate your time and help Jim
I notice there were some questions about the length of the Vapcell H10.
I’ve ordered the Vapcell H10 a couple of month ago, both flat-top & button-top (unprotected), their measurements are as follows:
Vapcell H10 (flat & button-top unprotected)
Vapcell H10 flat-top @ 49.1mm:
Vapcell H10 button-top (unprotected) @ 51.4mm:
The caliper I’m using is not that high-quality, so maybe error could be +/- 0.1-0.2mm.
I’m interested.
Could you convince Neal / Lumintop to sell the 16mm triple mcpcb and triple optic alone?
