Ok you lost me
Ordered 1 Nichia 3000K & 1 Nichia 4000K Thanks freeme
For raw impressive output, I’ve still yet to find anything better than XPL-HI for small triples. XPL-HI offers nearly as many lumens as LH351D, with much more intensity, neutral white color temperature, and excellent rosy tints. Also due to its higher forward voltage it tends to run cooler in these tiny hotrods than other LEDs like SST-20 or Nichia 219c.
If you want to impress your friends, XPL-HI tends to be the most impressive.
Unfortunately, XPL-HI does not come in high-CRI. My current EDC is a modified DQG Tiny 18650 IV running Anduril with three high-CRI Nichia 219C as emitters.
This setup is quite a bit lower output than XPL-HI, but I like the tint, color temperature and CRI.
Thanks for the info I appreciate your time and help Jim
I notice there were some questions about the length of the Vapcell H10.
I’ve ordered the Vapcell H10 a couple of month ago, both flat-top & button-top (unprotected), their measurements are as follows:
Vapcell H10 (flat & button-top unprotected)
Vapcell H10 flat-top @ 49.1mm:
Vapcell H10 button-top (unprotected) @ 51.4mm:
The caliper I’m using is not that high-quality, so maybe error could be +/- 0.1-0.2mm.
I’m interested.
Could you convince Neal / Lumintop to sell the 16mm triple mcpcb and triple optic alone?
I’m curious how hard flashling anduril 1 on this would be, I’m not a fan of anduril 2
That’s what Neals site has the measurements as when I bought some earlier
Just curious as to why?
Interested! 14500 is my preferred pocket carry size so this will be a welcome addition. Please ask them for a deep carry clip though!! Not even bothered about the two way, but deep carry makes all the difference
This :+1: . … I second the motion for a deep carry clip!!!
What were the changes in anduril 1 vs 2?
Yep…. make it a single emitter option, deep carry clip and offered by another/ a different vendor and I’m in! This would be my favorite 14500 EDC then!
So according to the measurements the button top batteries are 9/10ths of a mm over the stated maximum battery size I think that they will work. Right???
It’s possible but the tolerances on the FWXX series lights are so tight that it could damage the spring or the cell itself over time.
Are they going to include classes to get a degree in that,my goodness that loos confusing
I’ll admit it’s intimidating at first but once you have the light and understand the flow it gets MUCH easier.
Is that the anduril for the Fwaa
FWAA has Anduril 2.
Great I’m out of work on a medical leave,so I need to keep me busy for hours and hours, so looks like I’ll have something to help with that LOL
Interested in sst20 4000k.
