I would guess the result will be very similar to the Keeppower 18350 1400mAh P1835C3 published today. What are the odds of two different 1400mAh cells released at the same time? None.
Did not know Keeppower also released a 18350 1400mAh, hopefully they’ll follow suit and release a 26650 6400mAh. They probably have the same suppliers/contacts.
Can I leave a request for Sanyo 18650GA 3500 mAh? I used them several times and they broke quite often. On https://batterytools.net/ I have read several reasons for battery failure. For example wrong coast charge voltage, free inter-cell joins or associations, misfortune of electrolyte and tall and uneven temperatures. Like this, I have not noticed, and so I don’t know what to do. Can you tell me what is wrong with these batteries or maybe they have features in use? Thank you in advance.
I see just 3 entries for such a thing in AliExpress, out of which just this one is selling it in small quantities. The size is nearly a match of two C cells (26500) in series.
Nothing to write home about capacity or energy density wise. The «8C» discharge rate claim is the only somewhat noteworthy stuff. I wonder what is the target market for such a thing.
Energy density in batteries available to the public hasn't increased in the last 6 years or so, by the way.
Rather than taking your chances with Ockered, I’d go with Sofirn’s offering (SofirnLight.com).
Previously they were labelled PLBs (the 5000 mAh) and I believe these would be equivalent to Schockli 5500 mAh (lygte ). I just so ordered some, good pricing (for 2) and free shipping with orders above $29 (USD).
But if your query is for HKJ to test, disregard my post.
Does Vapcell have a rewrap of these EVE 33V battery? (there are too many Vapcell 18650 battery models right now, and it gets a bit confusing, which is a rewrap of which battery internally)
