I did not take into account that some of the radiant heat escapes through the aperture. Also, some is reflected by the die, giving it another chance to escape. If collar collects 75% of energy (pretty much the worst case) it ends up at just over 1W.
My gut feeling is that any mirror will work. The heat emitted is not significant.
In addition, I also believe a larger portion of the efficiency of a collar is not from the recycled blue but simply the white light.
LEP that use reflective laser has a much higher spike of blue since there isn’t really anything stopping the laser to refract/reflect off the surface, where as an LED or transmissive phosphor all of the blue light must pass. Any yet, I keep getting the same ~2x intensity when using the Waiven produced collars on LEDs, LEPs of all types phosphors.
When I was testing the solid crystal static phosphors with collar, they had a very bad absorption rate so there would be quite a bit of leftover blue; same results, about 2x intensity
I was thinking of trying to make my own collars and getting it sent in to be silver/Alu coated used in the Chinese plastic reflectors. Each batch costs like 150USD and can fit like 40 collars. They said the reflectivity is around 97%
I was never able to get a very smooth or spherical surface to continue with coating. Maybe we can do injection molded? The coating would fill up the small surface imperfections.
All I can say likevvii is WOW WOW WOW.
Thank you for the kinds words (:
I am currently working with an electronic engineer freelancer to produce the controller.
The controller will have a 50mm OLED, buzzer, and buttons
It will monitor and display every critical component sensors and provide warnings / automatic decision when certain values are reached.
Here are some features I plan to add:
(To control brightness, I have a 100mm slide potentiometer.)
-Software limited slow ramp up. Example: +20% per second. Ramping down is unaffected.
-Potentiometer state check. If output is 10% or higher when powered on or long idle; it will produce error message and tell operator to lower potentiometer to zero.
-Exponential brightness curve. A little bit more brightness resolution on the lower end.
“Warning. Core meltdown imminent. You now have 17 minutes to get to minimum safe distance!”
I imagine you have to monitor the wheel rpm, if it stops spinning bad things could happen quickly.
Useful ideas for your controller.
I would suggest adding circuitry for charging, including balancing and capacity-left option. Or what I like: Runtime left on current level. Some buttons for special functions like momentary-full-power is nice. And programming interface accessible without having to open the lamp: Once you write your own software, there will always be improvement ideas, and you will want to program oftenly in the first time....
Yep, I am using an IR RPM sensor directly reading the RPM of the wheel.
What would be some ways to monitor/measure capacity? Are there BMS systems that can output that data? Since I am running these cells at 70% of their maximum continuous discharge rating, they would voltage sag quite a bit so measuring voltage is not optimal.
I could put a current sensor but it seems like it would not remember capacity after disconnecting power.
My programmer will be using an arduino, so I just only need to edit certain variables according to my liking through USB.
if you used it in cold temps [winter], could it do even more?
how bright are all those candelas, compared to the sun at noon in summer?
wle
Regarding battery capacity: On my 1500W build I implemented the following calibration procedure:
- Battery is fully charged
- A complete discharge is performed
- During this discharge, once every 30 seconds the lamp is driven to no-load, mid-load, heavy-load
- Voltage value is stored for all three load cases, so three values per 30 seconds
- Once battery reaches end voltage (3V per cell), it is further stored how long total discharge did take
- Now the voltage level corresponding to certain battery fill grades can be calculated
- Internal battery resistance can be calculated from the voltage drop between the load steps
- During operation I then always look up the no-load voltage curve. Depending on lamp power level I then add a value calculated form battery current and internal battery resistance
- This work pretty good, when ramping lamp power up and down, my capacity keeps +-5% accurate
Knowing the battery capacity in mAh or Wh it is possible to use a hall current sensor and simply integrate to find the drained capacity %.
That’s how all these cheap battery capacity monitors work.
https://www.amazon.ca/Yeeco-Voltmeter-Multimeter-Capacity-Detector/dp/B073W6453F
These are all great ideas!
It seems with an integrated battery, by far the cheapest and immediately effective option would be to map the voltage profiles.
I will use this method once I have a permanent pack.
If I used capacity tracking, what would be some effective ideas to store the remaining capacity value? The auxiliary pack I use to power the controller and other components will be removed since they are my general purpose batteries. Based on my limited knowledge, If there is no continual power supply, we will need the controller to write and save to flash the capacity values periodically. Due to limited life cycle of flash writes, it may not be the best option.
Why do you plan to use a separate battery pack for the controller? Isn't it simpler to have that also derived from one main battery?
I also thought about doing an integration over current and voltage going in and out of the battery, but at >100A current sensing would have consumed too much space, and space is something I had nothing left....
Further, there is the effect of slow battery discharge during non-usage. Getting that not into integration would cause error; and a lamp can sometime lay around some days/weeks without usage.
So with that in background, I found the calibrated voltage method being suited for this application.
By the way, if you have an application needing permanent, non-volatile logging, using an MRAM can be an option.
Can be accessed like SRAM, but keeps content after power loss.
I’ve wondered if it would be possible to make a wide angle high intensity thrower by using something like phosphor wheel and a light directing. My line of thinking is like taking a thrower and scanning around very quickly. If we take a crt monitor or possibly and more applicable, DLP systems as inspiration. Highly directed light hits the sweet spot in the reflector or lens system but can also be scanned to other areas in the way a theater projector creates a seamless image.
Yeah that’s very possible, if you take a small actuated mirror like the ones inside laser scanners (used in clubs or festivals) you can make the laser move very rapidly in a small circle, which effectively increases the light emitting area on the phosphor it hits, making a wider beam.
The beam angle would only change by a couple degrees though, since the area you can cover would depend on the speed of the scanning as well as the phosphorescence decay time of the phosphor.
I have an update on the schematic.
Originally planned for 1 controller, but we quickly used up all the pins so we moved to two controllers.
I am not quite sure why I wanted separate battery packs. It does seem like unnecessary complexity. However, It just feels cooler to have it separate haha.
Something with 50V stepping down to 12~5V didn’t sit right with me.
We ended up deciding to use a current meter and the EEPROM to store Wh consumed. Also have a mini encoder switch to adjust starting Wh and reset tracked Wh.
The designer said even with limited writes of the EEPROM, it should be sufficient for this prototype while considering the complexity involved.
_
I thought If I added an actuator to the parabolic mirror, I could achieve flood mode too! I was very wrong.
The result is EXACTLY like Robin Dobbie’s GIF. There is no light at the center and just a halo ring of light getting larger as I zoom out. haha pretty garbage flood.
It seems some kind of lens needed in the system to have a useful flood mode.
I guess the real question is… When are these for sale?
Yeah, defocusing a reflector doesn’t work because the points on the parabola are at different distances from the LED.
This means that the center part defocuses a lot faster than the outer part because it is closer, which causes a donut shaped light.
With a lens this is not as extreme, since the points are not at such huge different distances, but it still does happen.
Creating a larger spot without a donut hole involves changing the diameter of the light source (aka the lit spot on the phosphor)
This can be done by defocusing the lasers, vibrating or moving them very quickly, or using a precollimator lens to magnify the source (if using an LED)
Any new progress to report? Looking forward to seeing this in action.
Yes, me too! I have a new Thor Lumintop LEP on the way. I’d love to have an LEP the size of my Imalent MS18
