varbos
(varbos)
April 21, 2021, 8:06am
408
I would have been interested if it ran off actual AA Alkaline/Nimh and had a single emitter, current controlled. Then it would be a flashlight I could gift it to muggles.
The name should be FW3A Mini. FWAA is nonsensical and will disrupt the naming convention. Knowing Lumintop there will eventually be single-emitter and quad versions … now what are you going to call them?
I’ve gotten used to anduril 1 on all my lights, I also don’t like how getting to turbo is no longer 2c from on, instead it brings you to ceiling, which I can change to turbo but would just rather have all the lights I carry to be uniform in operation
d_t_a:
I notice there were some questions about the length of the Vapcell H10.
I’ve ordered the Vapcell H10 a couple of month ago, both flat-top & button-top (unprotected), their measurements are as follows:
Vapcell H10 (flat & button-top unprotected)
Vapcell H10 flat-top @ 49.1mm:
Vapcell H10 button-top (unprotected) @ 51.4mm:
The caliper I’m using is not that high-quality, so maybe error could be +/- 0.1-0.2mm.
Thanks for the measurement d_t_a! :+1:
I measured:
Efest IMR14500 650mAh 9.75A (unprotected flat top) = 48.8mm
Shockli IMR14500 1050mAh 12A (unprotected flat top) = 48.9mm
Sanyo UR14500P 800mAh (unprotected flat top) = 49.1mm
Vapcell “Gold” ICR14500 1000mAh 3A (unprotected button top) = 50.8mm .
Vapcell H10 INR14500 1000mAh 10A (unprotected button top) = 51.3mm
interested in Nichia 4000K
Jimo
(Jimo)
April 21, 2021, 5:06pm
412
Hey everyone,would someone please post the diagram for the Anduril 2 operating system. I lost the one I had,Thanks Jim
I guess you are refererring to this, last page:
[image]
[image]
It’s possible but the tolerances on the FWXX series lights are so tight that it could damage the spring or the cell itself over time.
OB1Jacobi
(OB1Jacobi)
April 21, 2021, 6:34pm
415
Order placed for 2 with the sst20 4000k and a couple H10’s.
BOO5TED
(BOO5TED)
April 21, 2021, 7:00pm
416
You could keep any eye on this thread also.
I did a major rewrite of Anduril. For a long time, I tried to avoid changing the UI much, and stuck to only small changes so it could keep backward compatibility. This was holding it back though, so I finally did all the bigger changes I had been avoiding. The new version is called Anduril 2.
Current status 2020-09-30: Almost done; just finishing up a few little things.
What changed? A lot:
Uses a “simple UI” by default. This has only the core functions, like a normal flashlight — on (ramp),…
That’s where I got the UI diagram from.
Jimo
(Jimo)
April 21, 2021, 7:33pm
418
Did you get button top or flattop
lite624
(lite624)
April 21, 2021, 8:09pm
419
Interested in sst20 4000k
redsuns
(redsuns)
April 22, 2021, 1:34am
420
Interested: SST20 (4000K) LED
JaredM
(JaredM)
April 22, 2021, 4:38am
422
@freeme any comment on that beamshot with tint comparisons?
LedTed
(LedTed)
April 22, 2021, 6:19am
423
It’s too bad this is made by Lumintop. Professionally, I would reject every solder joint I’ve seen in this thread. The idea of this light is tempting. The reality of the production quality of the actual light makes me want to pass.
freeme
(youtube.com/@1thedeals)
April 22, 2021, 8:18am
424
I knew this is coming even before i posted it. Nevertheless, just trying to be transparent with our work. I have already left a feedback through Neal.
freeme
April 22, 2021, 9:02am
425
That's right. Try not to pixel peep my images. Haha. Anyway, they should informed by now.
