Make Yourself At Home With Home Lights & Lighting Sale UP TO 20% OFF
JETBeam JET-1M GUARDIAN Tactical LED Flashlight
4*LED / 6-mode / 1200LM / pure white & red & green / 1*18650/2*CR123A / clip / lanyard / IPX8 waterproof (2m underwater)
Head diameter: 27.5mm
Tube diameter: 22.5mm
1m anti-drop height
Patent temperature control technology for overheating protection
JETBeam JET-U EDC LED Flashlight
1*Cree XP-G2 LED / 3-mode / 135LM / pure white / 1*AAA / lanyard / IPX8 waterproof (2m underwater)
Max Beam Intensity: 518cd
Adjust the brightness by twisting the head of the flashlight
1m impact resistant
Head diameter: 14.2mm
Tube diameter: 14.8mm
JETBeam E20R EDC LED Flashlight
1*LED / 5-mode / 990LM / pure white / 1*16340/1*CR123A / clip / Lanyard / IPX8 waterproof (2m underwater) / magnetic tail
Reflector diameter: 22mm
Head diameter: 26.7mm
Tube diameter: 26.7mm
Tail diameter: 23mm
Max Beam Intensity: 9600cd
1m impact resistant
Fenix E02R Mini LED Keychain Flashlight
1*Cree XP-G2 S3 LED / 2-mode / 200LM / pure white / Micro-USB rechargeable / IP68 waterproof
Head diameter: 15mm
Tail diameter: 14mm
Fenix TK16 V2.0 Tactical LED Flashlight
1*Luminus SST70 LED / 6-mode / 3100LM / cool white / 1*21700 / USB-C rechargeable / clip / lanyard / APF / IP68 waterproof
Advanced Pulse-Frequency Transmission System (APF).
Instant activation and strobe with the dual tactical tail switches.
Stainless steel strike bezel inlaid tungsten steel breaking tips.
6*Cree XPL-HD V6 LED / 7-mode / 6500LM / pure white / 1*21700 / lanyard / IPX8 waterproof (2m underwater)
SMILING SHARK E215-2 Mini LED Flashlight
1*Luminus SST20 / 7-mode / 1200LM / pure white / 1*16340/1*18650 / IPX6 waterproof
MATEMINCO CSF-04 USB-C Rechargeable EDC LED Flashlight
1*main LED+3*auxiliary LED / multiple modes / 300LM / pure white+blue+red+UV light / smooth ramping / IP65 / glow resinous material
HaikeLite MT09R LED Flashlight
3*Cree XHP70.2 / 7-mode / 25000LM / neutral white / 4*18650 / lanyard / IPX8 waterproof
Reflector diameter: 71mm
Head diameter: 74mm
Tube diameter: 51mm
Working voltage: 3.7-4.2V
Beam range: 600 meters
Mode: user-defined 6 group/22-mode + electronic electrodeless diming
Fenix WT25R Pivoting LED Work Light Flashlight
1*Cree XP-L HI / 6-mode / 1000LM / pure white / magnetic USB rechargeable / magnetic tail / 105’ adjustable head / IP66 waterproof
1m impact resistance
Head diameter: 32mm
The Fenix WT25R rechargeable pivoting flashlight is specifically designed multifunctional workhorse for industrial maintenance and operations. What makes the WT25R special is the ability to angle the head of the flashlight up to 105 degree, allowing for multiple lighting directions. The pivoting head is perfect for hand-free use; you can either tail stand the light or use the heavy-duty body clip to hold the flashlight in your pocket. A third option is to attach the flashlight to a nearby metal surface with the magnetic tail. The WT25R features magnetic charging with the included 3400 mAh rechargeable Li-ion battery. The Fenix WT25R LED work light will become your favorite tool to use around the house or out in the field, especially for kinds of industrial workplace.
One Cree XP-L HI LED, with a lifespan of 50,000 hours.
1000 lumens maximum output and 220 meters maximum beam distance.
105 degree adjustable head for use at different angles.
Magnetic tail for hand-free use.
Magnetic charging with the included magnetic charging cable.
Battery level indication for instant checking of remaining battery level.
Lockout function avoids accidental activation.
Intelligent overheat protection against high surface temperature.
Q5 Rechargeable LED Flashlight
1-LED / 3-mode / 350LM / pure white / 1*18650/3*AAA
Working voltage: 4.5V
Head diameter: 37mm
Tube diameter: 37mm
Reflector diameter: 32mm
Light output up to 350LM
Beam distance up to 100-200 meters
Waterproof in accordance with IPX6
Can be used as self-defense bat in emergency case
Fasttech New Arrival! 4-Head Full Spectrum LED Floor Grow Light w/ Timer for Indoor Plant
UK / US / EU Plug
96*red LEDs + 192*neutral white LEDs
height & brightness adjustment / w/ tripod stand
1*Cree XHP70.2 / 6-mode / 5500LM / pure white / 4*18650 / lanyard
Utilizes one American XHP70 2nd generation LED.
Exquisite,powerful,long throw.
Maximun output up to 5500lumens.
Built-in intelligent temperture control module can automatically adjust the brightness output.Keep using camfortably.
Built-in magnetic charging.
Reflector diameter: 81mm
Head diameter: 86mm
Tube diameter: 51mm
Beam range: 903 meters
1*Cree XHP70.2 / 6-mode / 4000LM / pure white / 1*18350 / magnetic rechargeable / lanyard / IPX8 waterproof / OLED display
Voltage: 3.7-4.2V
Tube diameter: 25mm
Peak beam intensity: 10350cd
Built-in multi-function OLED display, can display various parameters
And settings
Built-in thermal control module will automatically adjust the brightness output to keep the unit from overheating
Impact resistance (1.5 meters)
6*Cree XHP70 2nd LEDs / 6-mode / 25000LM / pure white / 3*21700 / magnetic rechargeable / lanyard / IPX8 waterproof
Utilizes 6 pieces of XHP70 2nd LEDs. The lifespan up to 50000 hours with maximum output of 25,000lumens.
Powered by three rechargeable 4000mAh 21700 Li-ion batteries
Instant turbo output by double press the power switch button while triple press the power switch button, can get lowest output
High efficiency constant power supply circuits will maintain constant brightness
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
Combination of toughened ultra-clear mineral and anti-reflective coating glass
Aluminum SMD reflector
Aerospace-grade aluminum alloy body.wear-resistant Type II hard-anodized surface treatment
IPX-8 standard waterproof(2 meters submersible)
1.5m impact resistant
Tail stand capability
Head diameter: 56mm
Tube diameter: 51mm
Fenix WT16R Multi-purpose LED Work Light Flashlight
2*Cree XP-E2 LED+1*COB / 6-mode / 300LM / pure white & yellow light / USB rechargeable / IP66 waterproof / magnetic back & tail
The Fenix WT16R multipurpose work flashlight is specifically designed for industrial maintenance and operations. WT16R combines spotlight, floodlight and yellow flash, the innovative COB (Chip On Board Light) side light allows for reliable lighting and safe warning. The magnetic back is perfect for hand-free use; you can either tail stand the light or use the heavy-duty body clip to hold the flashlight in your pocket. A third option is to attach the flashlight to a nearby metal surface with the magnetic tail. The WT16R features charging function with the built-in 2000mAh Li-Polymer battery pack. The Fenix WT16R LED work light will become your essential tool to use around the house or out in the field, especially for kinds of industrial workplace.
2*Cree XP-E2 LED’s and COB floodlight source with a lifespan of 50,000 hours.
Built-in 3.6V/2000mAh Li-polymer battery pack.
Combines spotlight, floodlight and yellow flash in one.
Super magnets are placed in the back and tail of the light for metal connection.
Widened stainless steel body clip for firm connection to pack and pocket.
Made of quality plastics, anti-drop and anti-corrosion.
4*Luminus SST20 LED / stepless dimming / 4000LM / cool white / 1*26800/1*26650/1*21700 / lanyard / IPX7 waterproof
Head diameter: 42mm
Tube diameter: 33mm
Tail diameter: 34mm
Spring: Copper alloy silver-plated spring with ultra-low internal resistance
