In my humble opinion, an optional electronic lockout via 4 clicks from OFF is more convenient and more common. I have some doubts that „doubleclick“ from off is a good way to prevent accidental activation. Moreover, it clashes with the convention to turn on with turbo mode.
Maybe you could consider putting a Getian FC40 HighCRI LED into E70. It might cope better with these new design elements on the tube. To me E70 looks like a typical „lifestyle“ product but not like a tool for tough business - even worse as it seems the principle „function follows form“ is used here. The battery tube is a key element to pick up and dissipate the excess heat coming from the flashlight‘s head.
Double-click for on to prevent accidental activation is kind of irrelevant. This is what manual lockout or electronic lockout is for. This will be a deal-breaker for a lot of enthusiasts, but to be fair, it may appeal to regular users not used to double-click for turbo.
Why not revise the UI to remove the double-click and just make it single click?
Xhp70.2 in 6 volt generates a lot of heat at 5000 lumens and this little host with minimal thermal mass needs aggressive thermal throttling to keep it from melting.
I like the design, but I think a different emitter would have been better (sst70, hint, hint)
Похоже ACEBEAM будет соревноваться с IMALENT в гонке просвета. Двойное безумие щелчка. Взрослый человек мог подойти к дизайнеру, сдуть со стола то, что он нюхал, взять карандаш и поправить.
Unintentional activation is a problem. 2 clicks for on might be a relatively simple solution that many could learn to live with. But I haven’t seen the rest of the UI. I don’t understand the advantage to all that fancy design on the handle. I will likely never buy anything cold white again. And I don’t believe there’s any evidence anywhere that strobe is going to disorientate an attacker. Please stop claiming such nonsense. Yes any bright light is going to slow someone down a tiny little bit. But your next move after hitting them with a bright light or a strobe better be really good.
[quote = Oli] И я не верю, что-либо есть доказательства того, что стробоскоп может дезориентировать атакующего. Пожалуйста, перестаньте заявлять о таком чепухе. Да, любой яркий свет немного замедлит кого-то. [/ Quote]
Я поддержу. Фонарик - последнее, что вы используете для защиты. И уж точно не просыпайтесь, пытаясь ослепить злоумышленника морганием. На собак это совсем не влияет, а двуногое животное скорее остановит фонарик, используемый как тяжелый предмет.
I like the look, but the info lux-perpetua shared about the importance of the battery tube in heat dissipation seems much more important than a flashy look, a 5000 lumen edc needs every advantage to dissipate heat, so the look must take a back seat to the function of its parts. Also, I don’t like the no mention of even a NW option on the website. I also don’t like 2x click for on, I’d rather 4 click for lockout. This brings me to - that must be an E-Switch tail switch? So the blue tube carries the signal from battery negative to positive, I assume ? Is there any potential hazard or drawback to having that signal tube exposed through slots in the handle? Like if you had change or a key in your pocket, could there be an accidental short? I don’t know I’m asking.
I like that they were trying to find a solution to accidental activations,shows they were probably taking suggestions or maybe even following many of the comments on (maybe) this forum that members were making about the fw3a and kr4 style tail switches activating in peoples pockets. But 2 clicks to on, I am curious if that helps at all. I have had my light 4 click locked out and still activate in my pocket due to how it was positioned while I sit while driving, specifically. So guess how I solved the problem? I moved the location of the light in pocket while I drive and no more accidental activation. Essentially I would rather make a small adjustment to how I carry the light instead of the manufacturer adjusting the UI. just my 2 cents.
6500k kills it for many blf’ers who are what I am fast becoming…a ‘tint snob’. After about 45 lights I’m becoming far more selective on tint than I had been. Edjamacation I suppose.
Is that in terms of efficiency AND tint rendering? Nothing else would be coming close?
I have to say, this E70 in higher cost materials is visually attractive but more of a “bling” light. Not an EDC, because of the crevices for attracting dirt. Good that the sleeve can be removed for cleaning, but the operative word is “cleaning.” Imagine getting out your cotton swabs and pushing them through each and every hole/gap. Still, it’s a work of art. I would treat it as such. Not EDC. But what kills it for me is the UI. “double-click” from off is very non-standard. I’ve already tested this out with a RovyVon Aurora A8. Now this is a light that cannot be physically locked out, because there is no removable battery. They chose double-click for on, and hold from off to give momentary turbo. It’s… OK, for a keychain light. But not an EDC.
Frankly, if the E70 came with Anduril AND an SST70, I’d be buying one.
