Is 10A enough to run the D4v2?
10 posts / 0 new
fogus
Last seen: 5 months 4 weeks ago
Is 10 amps continuous enough to run a D4v2 flashlight?
I have SST20 4000K 95CRI, Neutral White – XP-L HI V3 3A, 5000K, and SST-20 Deep Red, 660nm LEDs.
Specifically, I am looking at the Panasonic NCR18650BD battery.
By and large, I don’t run max output. Just occasionally for a few seconds (e.g., to show off). It is important that while I’m showing off, I don’t blow my hand off with an exploding battery.
zoulas
zoulas's picture
Last seen: 1 min 24 sec ago
I would say no. Go with 30 amp +.
jon_slider
jon_slider's picture
Last seen: 21 min 59 sec ago
IF that is a protected battery.. it might trip protection, that is not dangerous, but can be inconvenient
Anduril lights work best with UNProtected cells because
1. Anduril has built in LVProtection, allowing it to use UNProtected cells
2. When you try to show off by using maximum output, an UNProtected cell wont suddently shut off, the way a Protected one does.
fogus
@jon_slider: it is an unprotected cell.
I’ve been using 30Q (15A) cells for a while and haven’t had a problem with them. They seem to be unavailable now.
What kind of cells would you recommend in particular? Got any model numbers that work great?
ArtieT59
ArtieT59's picture
Last seen: 6 hours 36 min ago
SOny VTC6, found here:
https://www.18650batterystore.com/collections/sony-murata-18650-batterie...
They arent cheap but they are every bit as good as 30q, some say better, some say the longevity isnt as good, bu ti think its so close you couldnt tell.
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
Sirstinky
Last seen: 5 min 19 sec ago
They are better than 30Q, hit harder with less sag and gold higher voltage longer. Can handle up to 25 amps up to 80 degrees C limit. 30Q is only good for 20 amps to 80 C. Yes, the 30Q lasts a bit longer, but I’ve been using vtc6 for a long time in my FET lights and they’re awesome.
ChrisGarrett
ChrisGarrett's picture
Last seen: 5 hours 10 min ago
D4V2 is claimed to hit 15A-18A on turbo, but I don’t own a clamp meter to measure myself.
That’s probably only for a short while, since it’ll be ramping down in 20-25 seconds.
That’s nothing to sneeze at.
Sheer awesomeness in the palm of my hand.
I use VTC-5As in both versions of my D4.
It’s like VTEC, but turbo!
Chris
ArtieT59
ArtieT59's picture
Agreed me too
fogus
Well, based on the recommendations above, I grabbed a dozen Molicel P26A 18650 2600mAh 35A batteries. They looked good. 400 mAh down from the 3000, but they were cheap and available and have plenty of amps.
Sirstinky
The P26A is a direct competitor to the vtc5A.
