I’m sorry, I did not mean to offend you and set you on this path.
514.83€ |(48 teile/los fracht frei) QB26800 NEUE MODELL 26800 6800MAH MODELL...
Smarter Shopping, Better Living! Aliexpress.com
KB, thanks! Those bigger cells definitely require custom fabrication, but with the 26800, KB did something relatively simple with a common light, the FT03, and I got quite a few 26650/26700 lights that may be capable of being extended similarly.
Not sure if you fabricated all those copper rings, or had some that just had to be machined down. I can't follow all of it because I don't understand all the lingo but I get the end result for sure now.
Not sure if you fabricated all those copper rings, or had some that just had to be machined down. I can’t follow all of it because I don’t understand all the lingo but I get the end result for sure now.
26mm Copper Crush Washer’s… the finished O.D. ended up being 29.8mm and the I.D. being 27.3mm for them to drop into the head on my FT03… made the driver contact out of .020” copper sheet and used my Precision Brand Shim punch…
Those big ol’ cells didn’t look too practical, at least the ones I saw. Low voltage, low capacity, insanely high current. What’s the largest cell that makes sense to use? The QBs don’t look too bad, but I was thinking some reclaimed cells might be a better deal if I was going to build a huge pack.
I never looked to closely but I’ve had the same impression.
And cell availability aside, there is a 26800 light out there. Modding a 26650 one is easier than fitting a larger cell.
For the FT03, I'll probably try copper single strand wire first for the spacers, but still do the driver retaining ring mod and swapping out the driver spring - I'll probably use a low profile brass button.
26 mm to 29.8 mm is a big bump - not sure if that was why you used the sockets? Didn't understand that part. the 26mm washers I can only find for $10-$12 for qty 6-10.
Think'n to order another HK4S SST-40 and swap in XHP50.2 3V's - should be a nice use of the big cell.
$46 at FT here: https://www.fasttech.com/products/1601/10073177/9738130, just posted today here: https://budgetlightforum.com/t/-/37772/1008
Update: Ordered one from FT - $46 total shipped, same price I paid for the first HK4S on coupon discount from BG.
I received 8 QB26800 batteries from Aloft Hobbies a few days ago and cycled one of the cells along with a new Shockli. Recharged two batteries after both drained from a HaikeLite HK4S which has a 2.72 volt cut off. An Xtar X2 charger is used for the test. First battery the Shockli 5500 mah and the second was the QB26800. Shockli charged 5715 mah, QB26800 charged 7330 mah. Both batteries are on their 3rd recharge. Shockli is very close to an earlier test within 12 mah. This latter batch of 26800 went up 206 mah.
If you guys are still interested.
ASTROLUX 26800 Battery Tube for FT / EA Series Group Buy For reference, this is my order timeline for our Group Buy Note: speed of delivery varies from country to country. [image] Samples are in today. 26800 tube for FT (left) and EA (right) [image] Thank Texas Shooter for bringing this idea. For EA01/ EA02/ EA01S/ FT02S Group Buy Price: $9.90 (usual $14.95) Freeme's Exclusive Coupon: F06272 [image] -----------------------------------------------------…
Signed up for everything. Good to hear about Amutorch and Nightwatch - that e-switch version of the Ni40 Stalker looks amaz'n!
FREEME ✌ ASTROLUX 26800 Battery Tube for FT / EA Series Group Buy - ENDED
Good job. Thank you freeme!
Ama-zoning a few nights ago and ran across the Alonefire X28 (I know, but their UV lights I have found to be a good value so I decided what the heck) that comes with a 26800 cell.
Humble delivery - light, cell and USB-C cable (that didn’t function) - no instructions or spare o-rings or anything.
SST40 (?) emitter with smooth reflector.
Light works. UI is Hi-Lo-Off. Double click for strobe. OK, quite crappy UI.
Throws a nice tight spot with pretty broad, dim spill. Says SST40 but much cooler than my FT03 SST-40. Maybe a just a bit less bright than FT03 at center of hotspot but tint difference makes it kind of hard to compare. Haven’t had them both outside yet.
Doesn’t feel like an expensive light, but other than the bad cable it seems to work fine and only $18 is why I was tempted.
We’ll see about longevity.
Posted here just because of 26800 discussion - maybe a good host and get a decent cell to boot?
Dang, it's listed for $28 now w/10% coupon. I would have bought one for $18 for sure. It appears to be about a 45 mm head diam.
Here on Alibaba it lists the head diam at 45 - had a pretty good guess
Is that a real SS bezel?
Dang, it’s listed for $28 now w/10% coupon. I would have bought one for $18 for sure. It appears to be about a 45 mm head diam.
I grabbed one off of Amazon Prime for $18. It’s CR@P. I thought for $18 maybe the threads would match some of my other lights. Compatible with none of them. Threads are rough with slivers left in. Bezel is Aluminum. Reflector gives a ringy beam profile. For the price I got a 26800 battery and a power cord.
Ohhh. One sign of a cheap light is that white plastic/brass setup in the tailcap. Thought maybe it's just the tailcap, but guess the whole thing is at that level.
Crap compared to lights double the price but the light works as intended, it charges fine, and a big decent cell to boot. I think for $18 it is a reasonable buy.
Err, uh, kinda bad parasitic drain too though…
Just in case others missed it, the ASTROLUX 26800 Battery Tube for FT / EA Series Group Buy was a success! If interested, click the link and make your requests.
Has anyone got a source for these batteries that ship to Europe? I found some on AE but don’t like the look of the store.
Everyone having good luck with these batteries so far?
Cannot find any on Ali Express or Banggood. This 26800 size is rather rare.
Queen Battery Store in AliExpress sells them, if I change “shipping destination” to “USA”, otherwise, the item won’t show up when I do a search, since they do not ship to my country.
Queen Battery Store link for QB26800 batteries in AliExpress:
This other store also lists the QB26800 battery (I’m not sure if they are legit or not), the original product listing can ship to my country for a relatively low shipping fee.
I actually made an order from this store last week (indicates can ship to my country for a relatively low shipping fee), but now this AliExpress store messaged me to cancel my order since they said they cannot ship to my country…
https://www.aliexpress.com/item/33034471590.html
When I checked the link again now, the product link still indicates they can ship to my country, but at a much much higher shipping fee…
Maybe can try if the above ship to your country…
I can only find one supplier on AE who will sell individual batteries. I have asked Queen if they will sell me two, and have also asked Neal as he sold me a flashlight with a 26800 in it.
