Go for it
What is bad about the pcb?
Go for it
The anod is welded together with a small resistor and lot of blow
Previous image was enlarger,working space is small for the point of my 60W Iron solder
otherwise I cut Led :)?
Afer the use I found slight unscrewed the pill on my s2+, could have as a consequence bad pressure of the mcpcb on shelf surface.I added another retainer ring(also right washers should be fine)take from a junk light that now lock the pill.It also secured by the pressure of battery tube.
If you like this hobby enough, get a hot air station. Getting components onto and off boards is a breeze with it.
Or, a smaller soldering tip from Aliexpress.
Either way, this sounds like a cool mod.
Hey Sari33, I’d recommend taking the extra retaining ring out of the S2+ head. Normally the head screws onto the body (battery tube) until they meet. There should not be a gap between the head and the body. The body does not need to touch the driver retainer ring.
Where there should be a gap is at the tail. That’s where the body touches the switch retaining ring or housing and allows the flashlight to be locked out by slightly turning the tail.
Or maybe I’m not understanding your issue.
No,sorry maybe the barrier languages.
First I tightened the pill then I put the retaining ring, this because I founded the pill a little unscrewed last time and now Is secure pressed.
IFAIK there has bever been a retaining ring on the head side of a Convoy S2+…
In the head-combo you’ll find in that order:
O-ring (rather thin green GITD)
glass lens
reflector
centering ring
pill
This should be enough to press the pill in with the body.
Maybe you should consider using a thicker O-ring.
As already stated, there is a retaining ring IN the pill, that does NOT touch the body.
I turned the diffuser into anti-glaring hat for a bicycle flashlight, which is to prevent dazzling people from the opposite direction. It didn’t look very nice, but it works.
All of my S2+s have a retaining ring to secure the driver. I prefer not to have them soldered in.
Whether or not a retaining ring is used has a lot to do with the type of driver. Some, with a ring of 7135 regulators need the retaining ring to be filed out on the inside to clear the 7135’s or are soldered in place instead of modding the retainer ring.
#MINETOO
Finally got the boards in to convert my Amutorch E3 to Anduril2 with RGB Aux LEDs. It was a very tedious mod, but after a couple setbacks I think it turned out really well. I made a custom attiny1616-based FET+1 driver and used Loneoceans’s RGB Aux board for the FW3x series.
Nice work Gchart.
Nice gChart, more next level modding.
Probably the shortest 21700 cell light (@95mm) with Anduril, a pocket rocket.
I think I’ll have dig up my E3 and give it another look.
great work gchart, nicely done
Replaced Thrunite Cat6 V2 reflector with TIR Optic.
The inspiration for this mod was the result of seeing user reviews of the Manker MK37 and U22III lights with large TIR optics. I was able to find a similar looking optic on AE.
The Thrunite Cat6 V2 reflector cavity/dimensions (~ 52x29 mm) worked well for this optic, which measures 47mm dia x 29mm ht. The hardest part of this mod (or any mod where reflector or optics are involved) was getting it properly centered and focused.
Optic (slightly lowered to help focus) with DIY spacer/centering ring.
FWIW in the screen captures (see below) from BLF member andreas0401’s video review of the Manker U22 III one can see the result of this optic vs a traditional reflector, in that case using the SBT90.2 emitter. I get analogous results with the Cat6 and XHP35.
White-wall shot showing traditional reflector hotspot from U21 vs the new optic in Cat6
Screen capture from andreas0401 video illustrating this optic in the field, broader hotspot w/less defined spill (NOT the Cat6 in photos)
Unlike most mods the result was not more OTF light, just less as spill.
edited with different photos
I want to love this light, and even more so with this mod, but I just know it will never get carried over my KR4 or SC62w.
May I ask, what were the setbacks?
I bought this D25A Ti with a problem. Sometimes the light would not turn on. And when it did work, the switch was hyper sensitive and would switch modes with the slightest touch of the tailbutton. It would also skip modes.
At first I thought the issue was the switch contact ring to the body… I made sure it was clean, including removing all lube with alcohol. I even cleaned the body ring that the switch seats on, with emery paper, to remove any potentially non conductive Titanium Oxide.
The switch was still hyper sensitive, so I suspected the issue was caused by the plunger on the switch remaining partly depressed by the too tight tolerance to the rubber boot. I sanded down the switch pin, a little… it seemed to help, but the light was still unreliable. Sometimes it would not turn on.
Rather than continue shortening the switch pin, I decided to wrap the metal washer in a few layers of packing tape. This seems to have solved the problems… The switch is now not hyper sensitive, it no longer skips modes, and so far, there have been no more failures of the light to turn on.
edit the next day:
The switch failed again, several times, intermittently
so I removed the spacer tape around the metal washer.
then
I cleaned the switch with an alcohol soak, and I think that helped.
I also wrote to ask EagleTac if they will sell me a replacement switch.
I’ve never had a Zebralight, so I won’t even begin to compare that. And while I don’t have a KR4, I do like Hank’s lights. Crazy thing though… the Noctigon KR4 and the Amutorch E3 are almost exactly the same size, but the E3 is 21700 whereas the KR4 is 18650. E3 dimensions: 95 (length) x 29 (head) x 25.4 (body). The KR4 is 98 x 29 x 24.
The difficulties / setbacks:
This makes me feel better that you go through some of the same frustrations I do on mods.
And yes one thing I’ve learned for certain with 7135s, the good ones are good and the bad ones are bad.
