【ツ】Promotion: Yakorsei GD12 dual switch light
Hello everyone,
Yakorsei is a new Chinese flashlight brand that is just launching their first product GD12, a versatile tactical EDC dual switch flashlight with some interesting specs. Chances are real good we will get to see more new, interesting flashlights of them anytime soon. In order to celebrate their debut they are so kind to get us a nice promotion discount on GD12.
$ 69.95 ➥ $ 36.34 (incl. free shipping)
Please order here: https://yakorseilighting.com/products/yakorsei-gd12-tactical-and-outdoor-flashlight
Please use code: Lux-Perpetua-2020
Specifications
  • Emitter: 1x Luminus SST40 6.000K - 6.500K 70CRI
  • Constant current buck driver
  • Maximum output 1.600lm with max. 219m beam distance
  • 380 hours runtime on Moonlight mode
  • Dual switch design with tailclicky and side switch
  • Dual mode UI (tactical / outdoor)
  • Dimensions: 135mm (length) x 25,8mm (head diameter)
  • Weight: 72g (without battery)
  • Battery options: 1x 18650 or 2x CR123A lithium-ion battery
  • Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized to military grade specification type III, anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
  • Water resistance i.a.w. IP-68 (up to 2m / 6.56 ft. under water)
  • Thermal management: GD12 automatically reduces the brightness level when the driver temperature reaches 55°C to prevent overheating
  • Reverse polarity protection to protect against improper battery installation.
  • Low voltage protection at 2.6V
  • Content of kit: GD12, 18650 battery with USB-port, USB-cable, spare tailcap, spare o-rings, pouch, lanyard and the manual
User Interface (taken from GD12 manual)
[reserved]
16 reviews already, and all … about pink wig?
Please disregard that. It seems to be a mistake in their web content management system. It will soon be corrected.
Update 2021/03/18:
The code in the OP has been reactivated.
Code already used says the website
Oh dear. :person_facepalming: I will ask them to activate the code again. Maybe the code was redeemed more often than expected. On TLF some members ordered, too.
Just tried it again and the code worked. I like the look of this flashlight.
Thanks for confirming, TheAuditor. Yes, for now the code is not limited anymore.
I have a number of Sofirn and Wurkkos flashlights so it will be interesting to compare the quality.
I ordered on e and it was despatched on the 26th March. No movement since. I chased and apparently it’s stuck in customs and Yakorsei have had to send additional documentation. No further updates in a week so there’s clearly an issue. I joined at received an order from Neal which got to the UK in a week. Mist find out how he does it.
Still stuck in customs apparently. Not sure which customs. I have requested a refund.
