This light looks pretty impressive.
I think the 3x 21700 setup is really smart, though I don't do multi-lithium-ion flashlights.
I’m in for 1 silver thanks Texas_Ace.
If I’m in it will be for a black one. But I’m hot decided yet, it competes my FT03-SBT90.2. That one is between 400 and 500 kcd throw so just half of the Wildtrail, but it is way smaller/lightweight too. Decisions….
Yeah, high drain cells will work best, although it will work fine with any 21700 to be honest, just lower output naturally.
Yes, they already accept flat top batteries, this is why they have the FET’s in the carrier for polarity protection, it allows for flat top cells to be used.
Yes, faster charging would be nice but the carrier charging / battery bank feature is basically a bonus / emergency option, Like always the best option is to charge on a dedicated charger whenever possible. Beefing it up for higher currents is possible but it starts to get much more expensive and bulky when you do that.
Basically there are common charge circuits available for 2A that are proven, compact and affordable. Above that you get into more custom setups as there is a lot less development in higher current mass production.
Along with added complications in the variable QC setup. Honestly I am impressed they were able to fit a 2A charging setup in the space provided. I think they struck a good balance of cost / size / complexity with the setup they have right now.
If people truly feel that the added costs and size of a more powerful charging / battery bank would be worth it, I could see if they could increase it to 3A, I don’t see a variable rate tech like QC being a good idea in a setup like this though.
I don’t believe so as they already had issues trying to ship batteries to me with the prototype.
I listed up the results of my thermal test in the OP. Long and short of it, it was ~6 mins until 60C (common step down point) and ran until the cells were dead without overheating the light. Although need to check the specs on the cells to make sure they are rated for 80c if you do that, the cells came out at 75c. The light itself will have no issues running until the cells are dead though.
Yes, pretty sure they intend to make these a production light.
I don’t have the MF02S but the 3x 21700 is basically the same size as the GT handle which is 4x18650.
I was going to try to get some comparison shots with a GT90 last night but I realized, I actually don’t have a working GT90 at the moment. I took mine apart for an optic mod I am working on and it is still in pieces. I only have a GT and GT4 working right now and those are not fair comparisons for this really.
I will try to get a pic of the reflector and LED today.
Personally, I don’t care about GT90 comparison beam shots, but would like to see some on it’s own merits. The GT was too big and unwieldy for my purposes, so I sold it. This one may work better
I agree, the proportions are better on this one.
The manufacturing pictures are very impressive.
I cant imagine they make S2+’s like that and sell them for ten bucks?
S2+ are made with a similar but much simpler process. They are made with only a lath and in a single machine step I am guessing and they will be made out of tubing to further reduce the machining. Where this light need multiple machines and multiple steps on the machines to finish everything, that really adds up quick.
2A charging is fine in my opinion. This is a flashlight first, the battery pack feature is a nice bonus.
interested in raw version!
Interested in the silver version.
It seems like a single LED version of the HK90 triple - very close in size and design. I'm really liking my HK90, tear down shown here: https://budgetlightforum.com/t/-/64075, and finalized mods and results here: https://budgetlightforum.com/t/-/64075/39
I'm sure I can tweak out better than 800 kcd on this WT90.
I am im.
One “Clear / sliver” for me.
If there are no more “Clear / sliver” left, a black one
