Ordered a cyan with cyan switch light and a grey with amber switch light.
Edit:
Thanks TimMc! for the heads up on the aluminum lighted switch.
Edit:
I bought a D4V2 E21 2000K without the magnet. I want it now !
Can the magnet ($ 2 only) be added or do I have to buy the entire magnetic tailcap (7 $ ) ?
I removed the spring from the tailcap and there is a small hole.
I guess this is the space to add the magnet.
I asked Hank but I’m not sure he understood my question: he offers me the tailcap at 7 $.
I’ve bought neodymium magnets at the hardware store, and grinding the correct size was a pain, I could only fine slightly larger ones and grinding them down to fit. It once I did all of that they still never worked right.
Personally i would buy the tail cap from Hank, but it sure a couple people on here that can walk you through the process
Thank for the answer
In fact, I want to buy the magnet from Hank with my next order but it seem he is only selling the whole magnetic tailcap
Just got a small batch XP-L HI T6 8D LED in stock, 2800K, 90CRI, we will not put it for sale on the site,
if you like it, please order the XP-L HI V2 5D 4000K version on the site, and send us an email,
so that we can use XP-L HI T6 8D LED for the light you purchase.
Thanks Hank! Sounds interesting...
Oh boy, looks like I’ll be ordering another kr4… and probably the d4s too… thanks Hank!
I hate to ask this question, but if you have the ability, is there anyway to give an estimate lumen rating for the kr4 or d4. I will look at the CREE data sheet and probably get a decent estimate… but I am just curious, more so compared to the 5d 4000k. I feel like my 5d 4000k lights are close to as bright as my 3a 5000k xpl-hi lights. Hoping the 8d is similar too!
Hmmm, the 8D's are T6 bin, so down 2 levels from the V2 5D's, so from what I've measured, they should be lower. How much to be noticeable is another issue.
Is not V2 5D 4000k and T6 8D 2800k?
Should be lower, right? I guess I do not understand bins well, so if someone could clarify, I would appreciate it.
I do understand one letter/number combination indicates distance from BBL (or maybe both?)
So much still for me to learn.
T6 and V2 are bins, for brightness or lumens output, not color, tint, BBL related, etc. Explained here: https://flashlightwiki.com/Brightness_Bins
The wiki has some good basic info, though dated, it's pretty much all or mostly relevant.
T6 is a brightness bin, 8D is the chromaticity bin, you need to check the XP-L datasheet , T6 means 280-300lm at 1050mA, 8D is below the BBL. For reference kaidomain has a 90CRI XPL HI T5 7C1, one bin lower and above the BBL, so I guess this a good deal.
XPL HI at 3000K is too warm for me.
I wonder if I can get a high-CRI XPL HI light by combining 2 or 3 of these high CRI XPL HI leds with maybe 1 low-CRI cool white XPL HI.
Thank you. Foundation of understanding is progressing. I am appreciative.
Hi Hank. Do you have a measurement of the lumens output and the throw of a KR4 and / or a D4V2 with these LEDs?
T8 8D should be 10% less brighter than the higher bin LED like XP-L HI V2/V3.
Noctigon KR4 Ti all colors available,
<p><span style="font-size: medium;"><strong><span style="color: #ff0000;">The boost driver upgrade is available for the quad version of XP-L HI, SST-20, Osram W1/W2, Nichia 219B R9080 versions, each LED receives 2A current. The driver is not...
According to the Cree XP-L spec sheet, lowest luminosity for the 8D bin is 280 while for the V2 is 400, so looks more like 30%, in theory. I was wondering if you had measured one to make sure.
https://intl-outdoor.com/kr4-ti-colorful-series.html
Awesome! I have another chance!
Hank any info on the new light DT8?
