Yes, those numbers sound very reasonable, also keep in mind that my throw numbers are almost always noticeably lower then others, I got 1Mcd on the GT IIRC while others regularly recorded 1.2Mcd for example.
I hear you and understand what you are saying. As I said I thought it was going to have a tripod mount until the prototype showed up.
The truth of it is that there is just not enough meat to fit a full sized tripod thread in the current setup without entering the main reflector cavity. Now it is possible that a tripod mount missing a thread or 2 could fit but then not sure if mounts would tighten down properly?
The other issue is size, if they extend the meat to fit the tripod mount, it will increase the grip size which is already large for most people.
I am thinking about practical options for adding a tripod mount. I like to have a viable option before I make a pitch. Put simply I can understand why they left the tripod mount off the light itself seeing the CAD designs and I don’t think I can make a solid case for it to be added all things considered.
That said, I am leaning towards the option of having an optional handle that could be mounted to the light, preferably something pre-made they can simply order but worth case they could make something. This gives the best of both worlds, handle for those that need it and smaller grip for those that don’t.
If people have alternate options I am all ears, I am not saying getting it into the light is impossible, just unlikely. I will have their engineer look into it for sure though.
They actually contacted me but were not interested in the prototype (can’t blame them, it is a different type of review for a prototype). They wanted to review the production model which I think they will be able to work out.
The flat spots on the battery tube at 56.5mm, does anyone know of something that would fit that as is? Or know what size the one in the listing is (although a bit pricier then I would like)?
That would be a lot easier then making something custom.
Liionwholesale.com cancelled my last 2 orders. About 4 ish years ago I got in the Q8 buy and had them shipped but this last year and half No one is shipping up here I even went to some craptastic Vapecells for my 26650s.
Regarding the tripod hole, I guess I’m having a hard time understanding why the opposite side of the switch cannot work? If of course the fins weren’t milled out, and it remained a solid chunk of metal? Does leaving that as a solid flat piece effect the grip? It doesn’t seem like it would effect the battery tube?
EDIT: I just watched the video again, especially the first 20 second when they are rotating the upper showing the head and the button hole drilled out, the fins on the back really look like they’d have just enough meat, if left unmilled and flat, for the threading. But when millimeters matter using my eye does no good. I
I don’t have exact measurements but comparing it to my GT tripod hole, there does not appear to be enough room in those fins for the threads. The bottom fin is deep enough but the reflector inside the light starts expanding, that is why the upper fins are shallower. By the 3rd fin, there would not be enough room for sure as it is only a few mm deep. I am not sure how thick the metal behind the fins is but the CAD drawing does not look like it would be thick enough.
I did ask them to look into it though and they are but they are much more receptive to a handle that can be added to the light understandably. I told them if they make the handle custom that adding a tripod mount to it would be great. We will see what happens.
