Interested
Can you send me two codes for XHP50.2
You had sent me a code for $48.96 but now its only reducing the price to $55.
Interested Thanks
Has anybody a coupon for this light? Thank you!!
Update on the Convoy holster:
Excellent fit but isn’t Molle.
Not a big issue as I haven’t belt mounted, but no way I could attach it to a Molle rig.
Artiet59, thanks again for the heads up.
I got both the xhp50.2 and the sst40 versions. Just noticed that the 50.2 version has drained a 40t whilst sat on a shelf, whereas the sst40 version still has full charge. That’s annoying. Has anyone else experienced this?
I had the same issue. What you are experiencing is probably because of high parasitic drain (standby current). Parasitic drain measured in my FT02S SST40 5000K was in the range of 30mA to 70mA, which was very high compared to a normal level (1lumen.com review showed 0.13mA). At the rate of parasitic drain, it completely drained fully charged battery in a couple of days.
If you have digital multimeter, I would advise you to measure it and contact Banggood. I filed a complaint with Banggood regarding this matter, and they arranged a replacement head for me.
Manufacturer are aware of the issue. Quickly make a video and file for claim.
Why Mateminco offering 4 x XHP50.2 5700, but Astrolux not?
Interested
Hi, does anyone know how to purchase battery tube like the one that include in astrolux FT02S? I need it for my FT03 light. I’m searching everywhere, but couldn’t find it.
Banggood or aliexpress link would be great.
Thanks!
I guess you mean the 26650-to-21700/18650 hard plastic adapter tube? I’m also interested in getting additional ones of this but haven’t seen it being sold (probably just need to look around better). Mateminco (Astrolux) bundles it with the FT02S/EA01/EA01S/MF01-Mini so I guess we could ask if they sell just the adapter tube…
error. del.
Here is 21700 to 26650 adapter. To be honest, I think it is overprice for a piece of plastic.
https://www.aliexpress.com/item/33006912271.html
If you cut your tube in a half it might work.
Or find a friend that has a 3d Printer to make one for you. I made a few, but right now I am out of filament so until my Amazon shipment arrives…
Can I have a code please
Sent.
Looks like I am getting a refund
Hi freeme , coupon code in the first page is expired could you send me a new code thank you.
And do you have any information when XHP 5700K will be in stock?
I want to order but I’m not sure if I should order 6500K or wait for the 5700K ( I don’t like bluish white light, I prefer yellowish light)
not sure 5700k will return its removed from options even on the light.
