It is strange to have the switch above the LED, and yes the grip does get hot but I worked with them on the thermal path quite a bit so the grip is only a few degrees warmer then the fins in my thermal test, so big picture it doesn’t seem to have that much of a real world effect on temps. Still took 6 mins to reach 60c at the grip in my test. I would say it is pretty close to the GT thermal gradient.
Loaded with cells the center of gravity is right below the switch it appears, feels pretty good in the hand. They got the balance pretty good for hand holding.
I also got word they are planning to make 70 silver lights, total time should be about 30-40 days until those are ready (largely depends on the China holiday that is coming shortly). No word yet on if they will include a tripod mount, not sure if that will make it into this batch.
I just noticed this- the silver picture is from 28 seconds into the OP video, And black picture is from the end of the video. Different head shape/design/roll stops. I like them both, but the silver one is nice. Kindve has a K1 feel to it. I wonder which one will make production?
I would be interested in testing/review of it. I could do vids as well. I have a better meter now I've been using for throw, as recommended by djozz - the Extech LT45, and even learned how to use it . I also have a set of Vapcell T50's I'd like to try out in this light, as well as T30's and T40's
Ohhh - didn't finish my post before bout reflector depth. Some manufacturers think they need depth for max throw, so they add quite a bit to the length of the light, which is mostly a waste. Unless you really like the reduced spill area, and probably more brighter spill, I don't see the point of added length for basically no gain in throw.
I see what you’re saying about depth / vs. pure kcd benefit, makes sense. I guess I’d be neutral on it unless it added too much to the length of a light or really interferes with other design aspects. Good info I appreciate the explanation.
And I REALLY hope the prototype finds your doorstep. I think we would benefit from you having this light on your work bench. I know it’s helped me with other lights in the past. I’ll speak for myself, and I know others feel the same. Thanks guys.
Also- TA, any update about when We can PAY for this light? Lol. I have the money Burning a hole in my pocket :innocent: and I don’t mind the whole “group buy” aspect where you throw your money in the hat before production is done. If that’s an option, If not no worries.
After past experiences, I don’t do pre-pay anymore. Just too many possible issues and very little upsides.
They are supposed to be ready to go live with the listing in around 2 weeks depending on the china holiday that is going to shut china down for a week or so next week I think.
I do like deep (but not extremely deep) reflectors. While spot brightness is not affected, some of the spill that is in shallower reflectors is in deep reflectors converted into a bit wider hotspot, which is where I find the light more useful than going to the side.
This Wildtrail light, from what I can see, has about my ideal reflector depth.
i am getting very excited for this WT90, specifically because i got my MF02sV2 delivered last night, which is an awesome light. And this WT90 (i believe) will trump the mf02sV2, based on the reflector width (74mm vs 90mm), battery type (3 30t’s or 40t’s!), and design for thermal capabilities. I mean i could be wrong, and i really like my mf02sV2, but i see this WT90 being on a whole different level while being close to the same size. which is exciting.
Oh, and plus the WT90 has Narsil UI, which is just MUCH better then the stock Astrolux UI, i think most of us would agree. lol.
That MF02S v2 rating of 6500 lumens is way out there. I see Flashaholic got more reasonable #'s, think 4800 at 30 secs, 5600 at turn on. I'm even surprised it got 5600 lumens at turn on - that's impressive for a SBT90.2 in a factory stock light.
I'm assuming the short MF02S v2 has 4 parallel cells?
