I tried to disable Simple UI in my cfg-*.h:
#ifdef USE_SIMPLE_UI
#undef USE_SIMPLE_UI
#endif
But I was getting an error while running make due to some references to Simple UI in ramp-mode.c:
ramp-mode.c: In function ‘ramp_config_save’:
ramp-mode.c:425:26: error: ‘simple_ui_config_state’ undeclared (first use in this function)
if (current_state == simple_ui_config_state) style = 2;
ramp-mode.c:425:26: note: each undeclared identifier is reported only once for each function it appears in
ramp-mode.c: In function ‘nearest_level’:
ramp-mode.c:480:41: error: ‘simple_ui_active’ undeclared (first use in this function)
uint8_t num_steps = ramp_stepss[1 + simple_ui_active];
ramp-mode.c: In function ‘ramp_update_config’:
ramp-mode.c:508:9: error: ‘simple_ui_active’ undeclared (first use in this function)
if (simple_ui_active) { which = 2; }
I fixed it by adding some conditions:
=== modified file 'ToyKeeper/spaghetti-monster/anduril/ramp-mode.c'
--- old/ToyKeeper/spaghetti-monster/anduril/ramp-mode.c 2020-10-17 02:45:24 +0000
+++ new/ToyKeeper/spaghetti-monster/anduril/ramp-mode.c 2021-04-19 00:31:52 +0000
@@ -422,7 +422,9 @@
// 0 = smooth ramp, 1 = stepped ramp, 2 = simple UI's ramp
uint8_t style = ramp_style;
#endif
// save adjusted value to the correct slot
if (value) {
@@ -477,7 +479,11 @@
// bounds check
uint8_t mode_min = ramp_floor;
uint8_t mode_max = ramp_ceil;
- uint8_t num_steps = ramp_stepss[1 + simple_ui_active];
+ simple_ui_active
#endif
// special case for 1-step ramp… use halfway point between floor and ceiling
if (ramp_style && (1 == num_steps)) {
uint8_t mid = (mode_max + mode_min) >> 1;
@@ -505,7 +511,9 @@
// ensure ramp globals are correct
void ramp_update_config() {
uint8_t which = ramp_style; -
if (simple_ui_active) { which = 2; } -
#endif
ramp_floor = ramp_floors[which];
ramp_ceil = ramp_ceils[which];
Revision: 586
https://bugs.launchpad.net/flashlight-firmware/+bug/1925009
