I donāt need it, manufacturers do for false advertising.
CRI and constant brightness till battery deplete I care.
Mike
Why do sports cars have a vmax of 200mph? Nobody would need it IRL.
To see what is possible, to market it the right way, so we can brag on BLF what we built.
My more expensive lights can do thousands of lumens, I donāt use them ever in that setting.
For me, the question of choosing a flashlight whoās highest mode will run for hours and hours and hours, versus a flashlight whose highest mode will run only for a few seconds, is a matter of personality. Thatās why I like both kinds.
idk ? for fun ?
Lights are improving tremendously so the days of 5 second turbo are almost behind us. The new SP35 for example implements spectacular ATR that is barely noticeable.
Yes.
I have an Emisar D4V2 Sand with XPL-HI V2 5D 4000k. ~18A with a Vapcell S30 on Turbo for a few seconds.
I bought another Emisar D4V2 Cyan with XPL-HI V3 3A 5000K last week. :person_facepalming:
Theyāre fun!
Some people get annoyed at the short runtime on Turboā¦ get a bigger flashlight!
Itās the āWOWā factor. Practicality comes in sub-turbo modes or ramping capability. Nonetheless, itās nice to have mega-tons of light to scare away the bogeyman, or punch a 400 meter hole in the night if so needed or desired. I just know that every time I double tap the go button on a barn burner light, thereās a big āol smile on my faceā¦.and it tends to last longer than a turbo blast.
Its the same thing with megapixels in cameras. The perceived idea is the higher the number the better. Fact of the matter is you would not buy a new 5MP camera today. There was one Imalent light I donāt recall the model where it did 100K lumens on turbo for something like two seconds. People donāt see the two seconds, they see the 100K lumens. Human nature I guess.
Those super-bright lights are for fun, too big and heavy for carry or camping anyway. So I have a 8000lm flashlight and it falls back to 5000lm after some time, that makes it still pretty bright even when fallen back a little so I donāt care that much. For practical use I really donāt need that much light and donāt like to carry 434gr. of flashlight for a longer time so I have other lights for practical use.
Flashlight manufacturers should advertise their lights like this (just an example):
4000lm max output for 60 seconds (@ 25Ā°C ambient temperature, zero wind speed /also mentioning battery, which was used during measurement/)
700lm sustainable output (same environment specs, output after temperature regulation settles).
This would speak clear enough for most of the users.
Anyway, I also find, that flashlights with turbo lasting only a few seconds are impractical, and an annoyance to use. From cold state, I need turbo to last at least 60 seconds - this is enough for scanning around briefly for identifying important objects in my surroundings (but for some use cases, I would prefer it to last several minutes, even if it isnāt so high level).
i use it about every day
it;s for when i need to see as far as possible, if only for a few seconds
why would you not want that, no matter how bright it can run all day ?
- in any design, there is usually more light to be had, if it doesn;t have to run long
iāll take it
i also do not like giant heavy lights that do not go in a pocket, it;s a good compromise for me
600 lumens all the time,up to 1600 for 10 sec
it beats either big heavy lights, or NO turbo
but that is just me
Iām probably not the only person sucked into buying a light due to max lumen claims on the packed. Iām pretty sure I wonāt be the last. Manufacturers are in the business of selling lights. They also donāt tell you next too the 1 month runtime claim that itās on moonlight mode at 1lm. Big spec numbers sell lights.
We donāt. We need as much sustainable lumens in the smalles body possible. Since that is not possible, we make concession
I don't know if I need that, but I do want that.
I prefer turbo to last at least a few minutes, even if that means turbo isn't nearly as bright.
That is more useful to me than super bright turbo for only ten seconds.
like my convoy l6 can do highest turbo 3000 lumens something nonstop no termal stepdown really until batteries wear down firstā¦ but can i fit the light in my pockets ? not realyā¦ but a fw3a and similar that can punch out almost that evne for short time is fun xd
You need to look at the mass of the light, something like the fw3a canāt possibly put out high power for too long. You can tell this by just looking at it.
I prefer cri (r9/r12). I sometimes use turbo to see far, but since Iām trying to make perfect long range shots, turbo seldom lasts long enough.
In fact, most lights canāt even sustain āhighā which is ridiculous. All lights should have a larger mass and efficient buck driver imo
Max outputā¦Turbo whatever you want to call it.I have NO use for lights from factory whose drivers only sustain Turbo for 10, 20 30 seconds or whatever.
I have a dozen modified lights that sustain Turbo for awhile.Basically they sustain the highest output possible in direct proportion of battery depletion. The output loss is not that noticeable until 10, 15. 20 minutes later until battery depletion.
Those are the lights I like.In addition my Hand determines the step down in warmer months, Not these bursts/ timed step downs that are for amateurs!
Good thing that you have expensive, large and heavy alternatives!!
Well, in my opinion and experience turbo is actually pretty useful when you need that extra light, even if it doesnāt last. It goes without sayibg that a small host with minimal heatsinking wonāt hold high output for long until throttling back. A big light with lots of thermal mass or active cooling will be brighter longer also. As was mentioned, thermal management on the UI side has gotten continously better also.
