Brighten Up Sofirn BLF LT1 Lantern With A Pencil
28 posts / 0 new
vietnamreviews
Last seen: 15 hours 58 min ago
Robin Dobbie
Last seen: 39 min 13 sec ago
I just got flashbacks of trying to overclock OEM tray AMD Durons.
CR888
Last seen: 3 hours 56 min ago
Interesting wonder what the LT1 guy here who designed/led the creation of the lamp has too say about this. Should I try this 300 free lumens sounds great!
CR888
iamlucky13
Last seen: 1 hour 32 min ago
Nice video for showing how easy it can be. Thanks for sharing.
It was intentional on Lexel’s part. I believe it was a group decision that it would be a nice feature for the number of 7135 regulator chips powering the LED’s on the LT1 be configurable. Each chip provides 350mA of current. 3 of them on each channel are inaccessible to the user and always connected (maximum driver current can be limited to 1050 mA).
2 more are accessible and come pre-bridged from the factory (default maximum driver current is 1750 mA) with either a solder blob or a small resistor. Those can be removed if desired. Although it may seem undesirable to limit the maximum brightness, it also reduces the minimum brightness so you can have a lower moonlight mode, and should very slightly improve the efficiency.
Or the remaining 2 can also be bridged by the user to take the maximum driver current up to 2450 mA. That is what is being shown in this video.
The normal method is to bridge the pads with solder, but because these pads only need to power the signal pin on the 7135 regulator chip, the power level is very low, and ordinary pencil graphite should be conductive enough to work. Note that the graphite for mechanical pencils has wax or plastic in it as a binder for extra strength, and is generally not conductive enough to work.
Source:
https://budgetlightforum.com/comment/1408092#comment-1408092
DBSAR
DBSAR's picture
Last seen: 58 min 4 sec ago
It was designed to have that feature. Big Smile originally it was intended with those channels left open as an option to “boost” the LT1 to hither than factory outputs, by bridging the two contacts, which adds more 7135 regulator chips in the output stage. (solder, or a high graphite content pencil.
vietnamreviews
Yes. That’s great
gravelmonkey
Last seen: 7 hours 59 min ago
Not exactly free, reduced runtimes, greater heat.
I’ve soldered mine, but have set ceiling ramp to approximately the original highest brightness.
Double click to turbo will do the full (modified) output, but I don’t like leaving the light unatended in turbo for fear it’ll get hot and fry the LED’s.
CR888
You see you need to pay attention and ‘be in the know’ with these cleverly designed lights. Many secrets lie within. It’s pretty cool I’m sitting half way across the world with my LT1 apart on my coffee table unlocking it’s hidden talent with direction straight from the horses mouth! (I don’t mean your a horse). But it’s good, got muh HB pencil & about to do surgery.
CR888
DBSAR
DBSAR's picture
[quote=CR888
You see you need to pay attention and ‘be in the know’ with these cleverly designed lights. Many secrets lie within. It’s pretty cool I’m sitting half way across the world with my LT1 apart on my coffee table unlocking it’s hidden talent with direction straight from the horses mouth! (I don’t mean your a horse). But it’s good, got muh HB pencil & about to do surgery.[/quote]
Big Smile Beer Beer -We built the LT1 to have a good balance of output and run time with its factory configurations. The extra 7135 chip pencil/solder mod is there for those who want to boost the output a little more in sacrifice of runtime. (keep in mind the head of the LT1 will also get hotter too.
Funtastic
Funtastic's picture
Last seen: 3 hours 32 min ago
I thought it had thermal regulation?
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Sunnysunsun
Sunnysunsun's picture
Last seen: 39 min 29 sec ago
Nope, the LT1 doesn’t need it and doesn’t have it. The top gets a bit hot but not to the point of being too harmful.
Funtastic
Funtastic's picture
Not even when it’s running on all 8* 7135 chips?
Sunnysunsun
It has 7 7135s which means 2.45A at the head. That’s about 7.5W of power and the LEDs turn some of that power into light. I have a 5W little usb heater with less surface area and its heating plate reaches about 80C when constantly on. The LT1 has more surface area to shed heat and the LEDs (probably?) turn more than 2.5w of that into light.
ZedLep
Last seen: 2 days 18 hours ago
Ý tưởng tốt. Cảm ơn bạn
DBSAR
DBSAR's picture
Here are the temperature tests i did with the factory and all-enabled chips: >> https://www.youtube.com/watch?v=m2jEtJOjd2c
gravelmonkey
I’d not seen that one before! Thanks for a great vid!
Is 7*7135 run at lower output more efficient than 5*7135 at full??
DBSAR
DBSAR's picture
7 ~ 7135 is about the same efficiency at roughly 78% output, to the 5 ~ 7135s at full.
gravelmonkey
Great to know! Thanks again!
CR888
I did the pencil trick and noticed a reasonable difference but also it’s hard to tell unless you have a modded one next to a stock one. Worked good. I like my LT1 lantern. Used it tonight loading my truck with nice cut & split Redgum for my fire. Was thinking the other night, given the lt1 battery size/tube is similar to many pop can size lights a decent ‘optional extra’ could be a multi emitter head to convert it into a flashlight. But then again I thought if I had that I’d want an extra body tube!! Facepalm Looking forward to the next generation mini when it comes out.
CR888
gravelmonkey
I’D have to check, but my BLF Q8 tube works with the LT1, or vice versa, so essentially what you wish for does exist!
You’re right that you might as well have the tube too, Good place to store spare cells is in a light!
CR888
Good news! I don’t have a Q8 either.
CR888
DBSAR
DBSAR's picture
Just buy a Q8 from Sofirn for the flashlight part & use. Big Smile
CR888
The Q8 is on the list I saw some beam shots which looked good. I receny had a blf36-pro arrive which is kinda similar, it’s a 3×18650 8k-lumen. Im a biqt of a sucker for Sofirn lights, for the money they are pretty good. What I’ve been trying to find is the right size collapsible silicon bowl to do what DBSAR did making a ‘shade’ cutting a whole the diameter of the LT1 fitting it to the top to direct light down/across. I also like being able to use 1-4 18650’s in the lamp, that’s clever.
CR888
gravelmonkey
I put 4000k LED’s in my Q8, I much prefer the tint! You can also get a nice plastic diffuser for the Q8, completely different to the LT1, but good for a “work light” or similar.
Re. Bowls, I think it’s one of those Chinese products that are all produced in the same factory. You’ll probably want a white one to avoid casting colourful light all around the room.
Theyre pretty cheap, 3-5 USD on ebay, they all look the same- they’re the ones with the black coloured, hard plastic rim, with a cheap and nasty carabina.
Black plastic rim can be carefully removed to help minimise pack volume.
Don’t cut the hole too small- mine is only just snug enough. I’ve taken the orange o-ring around the top off and the shade fits neatly in the groove.
Re. 1 to 4 cells, I know different folks have different views, but I’ve a couple of sets of 4 cells, which I specifically keep married together so they all behave the same and are always the same level of charge to avoid any problems… Thumbs Up Beer
vietnamreviews
Sounds pretty cool
DBSAR
DBSAR's picture
I found mine on ebay, something like this one: https://www.ebay.ca/itm/154062434691?hash=item23ded63183:g:eF4AAOSwVvRbD5vP
CR888
I’ve seen the lamps with the orange Oring, mine didn’t come with one unless it’s still in the box, but it has that nice recess machined into the lid. Ive seen the silicon bowls with the carabiner. I think from memory had a little tab that the carabiner went through. DBSA has kindly put up a link below which I’ll just buy. I got 2 diffusers for my SP36pro from AliExpress Sofirn store which were the plastic testube shape. They perform well but I don’t like how they fit compared to silicon ones, they seem to require a hammer to stay on! lol. Same with the diffusers I got for little SP31-pro’s through Sofirn, I ordered 3 diffusers, 3 magnetic tailcaps & 3 short 18350 body tubes. They sent 7 diffusers, eight body tubes & 4 tailcaps!!! While I like the generousity of Sofirn China I just wish their diffusers fit better and stayed on the lights. I’ll only buy silicon ones from now on like I have on my MF01S, MF01mini, FW4A etc. I think the silicon shade would be good when you sit the lamp in a table and want to turn it up & not have your eyes cooked. I have 2 30q’s in my LT1 which are probably not the best cells for this light but when turned down I can’t believe how little power the LT1 uses with 4× 3500mAh cells it would near outlast religion!
CR888
CR888
Thank-you Sir
CR888
