A lot depends on how fast it steps down. A few seconds is useless.
But something like a Streamlight Protac HL 5-X
Gives a little extra for a short time. Maybe all ya’ need for a quick peek.
Of the late lamented Tacklife.
But make no mistake, I would sure like a mode that gave me the maximum brightness sustainable without stepdown.
Allowing for external conditions. Winter in Michigan vs Summer in Texas.
All the Best,
Jeff
“Are you willing to buy a light that is super bright but only has a limited run time at turbo brightness?”
yes.
it was the only style available
at the time which i could afford.
“How do you usually use the turbo mode?”
illuminating trespassers.
human and animal.
I don’t know how it does it but my Convoy M3-C sustains the max setting for a long time.
I find turbo to be extremely useful in many scenarios.
That said, if I had no use for it, I’d just simply not use it. I’ll take the option for a heavy slam of extra light any day though. I prefer options.
If turbo didn’t exist, I’d definitely have stayed a muggle.
Why do you need to be able to run if you can only hold 50 or 100 meters at the top? Surely you don't run every day, but do you want to be able to run?
I scan at an appropriate throw for the terrain until eyes glow in the distance. Then double click to see what they belong to. Very useful and practical for those who do not live in a city.
So I asked my wife if she would prefer a small one that had very high output for a few seconds or a bigger one that sustained a lower output for much longer. She thought about it and asked “we’re talking about flashlights right”?.
Turbo with temperature regulation is fine by me, even if it’s short lived. I don’t like timed turbo since the flashlight can easily be turned on again into turbo and can cause LED damage.
Some temperature regulation is better than others. ZebraLight is awesome with so many step downs that it’s barely noticeable. And it’s very quick to go brighter again if you disperse the heat like holding the flashlight tightly in your hand. Others are slow to respond and have very abrupt step downs, but better than nothing.
If you want more lumens longer, then you will need to get a bigger flashlight. Simple physics. I usually use smaller EDCs (like an S2+), but when I use my “big” Meteor M43, I’m always impressed with how well it can absorb and disperse heat to allow so many lumens for a long time!
… until you accidentally drop it and the filament breaks.
I hated that when it used to happen with my old incandescent lights.
if you are outside, and it is really cold, turbo goes longer
This problem is quite easy to solve. Get a bigger light. There us nothing like bigger mass to combat heat. All of the edc type lights are a compromise in more ways than others.
We all want that perfect edc that can throw like an FT03 but is the size of an fw3a. Does not exist unfortunately.
So what do we do now? We get both.
There are few practical examples - weapon lights for hunters do need to be light and punchy for few seconds, where short maximum turbo comes just in place. Another example is Lumintop X9L being just about the biggest light I would put in jacket - great beam profile and long sustainable runtime, but turbo is also there if you need it.
This is silly. For a given size and whatever, there is an upper limit for heat dissipation. Let’s say you can buy two lights: a D4v2 and a modified D4v2 that will only run at the highest sustainable brightness and no brighter?
Well, the D4v2 can do that too, but it also can do short turbo bursts if you need them for something. Heck, maybe your hands are cold. Maybe you need to light something on fire. Maybe you have to see across a parking lot briefly and the tiny TIR optics won’t throw that far unless you unleash all 3000+ lumens.
FW3A works that way for me. Great indoors, a common carry for me. Super useful at close ranges. So that’s really appealing. But if I hear a noise while I walk to my car, I can get 2000+ lumens to figure out it’s just a cat hiding under a nearby vehicle.
I am no longer interested in pocket rockets. Been there, done that, bought the t-shirt.
For a compact single-cell EDC flashlight, I need a few hundred lumens, good efficiency and a well-balanced reflector. Not some multi-emitter toy that can start fires and has a stupid UI
This must be one of the most common topics here
There is no right or wrong answer, it’s a matter of personal preference. For me, lights with an Andruil type “momentry” mode are quite useful- I use the seconds of extra output to take a couple of pics of whatever I’m looking at with my phone.
Discussion of turbo modes never seems to coincide with geography/climate… For lights with thermo-stepdown, only a few degrees cooler temperatures makes all the difference.
I’ve used my D4 in the tropics and also in Northern hemisphere with snow… Where the ambient temperature is already 25C+, you have practially no overhead before the thing overheats… If the ambient temperature is 3C, Turbo lasts a lot longer…
I have no doubt that knowing the light’s power output, the mass and specific heat capacity, and a bit of maths, one could work out the difference in runtime between 3C starting temp and 23C starting temp….
The question isn’t “why, need”? The question is “why not”?. The op answered this question already, to be able to see a little bit further or clearer down range. The vast majority of times when I pull my EDC out I’m going to have it on for less than a minute anyway. Do I normally go right to turbo? No. But it’s there if I want it. So it’s a useful feature. Don’t try to argue that it’s not. Is it confusing for some people? yes. Should turbo be measured at 2 seconds only with a full battery? No. 30 seconds, ok. Would getting rid of published turbo numbers help us understand how much light would be sustained after 10 minutes, 20 minutes? No.
My opinion:
“turbo that lasts a few seconds” would not really make sense, except as a self defense utility.
Turbo that lasts 30 seconds or longer makes sense to quickly check things at night in the distance, filling light for photography, inspection light to see in hard shadows during sunshine, etc.
Like for example the IF25A with manual calibration and adjustment, a turbo of three minutes with acceptable heat buildup is extremely useful in many situations where a bright flashlight is needed. I think 80% of times, the flashlight runs full power for a few minutes anyway. A 75% power ceiling as continous output does totally enough in most situations. At night walk, the power setting needs to be just around 20% to not glare too much.
So for me there is no need to carry around pounds of cooling fins, as long as is works as required without them. There may be uses for a continous power output, like lighting up a tennis court or a golf course, but this is the job of specilized lights, not necessarily flashlights.
To wrap it up:
It is always better to have an available reserve than to be in need of lighting power, while weight is one of the biggest factors in usability.
OP: Why do you need turbo that lasts a few seconds before stepping down?
Because, it’s AWESOME
