thank you very much for the kind and supportive words. You have very good tasteā¦
fwiw, that Nitecore EX11.2 has an sw45k from Bob McBob. It is the most pink variant, a D200, highly recommended.
andy zhu also has sw45k, they are D220 and are nice too, less intensely pink.
in the past andy also had sw45, non k, and less pink of the three, but still has a slight pink tint, noticeable when compared to CW and Low CRI Leds whose DUV (Tint), is farther above the BBL
andy has a great variety of other 219b LEDs tooā¦
I like the sw30 he has too, recommended.
Nice mod NeutralFan! And always clean :heart_eyes:
Hum, to help answering jon_sliderās question about Anduril driver, would I be wrong saying that: to use a driver with that firmware in a Convoy S2+, it would need some major mods (inner tubes, eventual pill adapting, different switch, ā¦.) to make it work, and that to use this kind of driver (FET) with those leds, it would need some āthrottlingā to maintain the max current on/under 4A?
Or a piston drive , which I assume isnāt much simpler to achieve .
Anduril isnāt limited to FETs (which indeed would burn the E21As E17As) 7135s can be used for constant current, also linear FET or buck/boost.
Mike Cās B17 clicky boost driver would be more suitable, while not Anduril I imagine his UI will be much more advanced and configurable than Convoyās, it is also much more efficient, with proper moonlight, regulation for the full battery etcā¦ a very nice upgrade for an S2 and compatible with quad E21A/17A since those can be configured as 3, 6 or 12V.
Thanks for the correction and further information thefreeman
I wasnāt considering MikeCās driver as it is not ācomercializedā as other drivers with Anduril, but it is too an option for mechanical āclickyā flashlights!
A piston driver such would also imply some modding too so I guess that it would be no different from the e-switch in terms of work!
One of my favorite lights in my collection that I will never part with got a new shorter tube to try on.
Quite awkward to hold with 18350 but I had to see. Thorfire C8S Switch, Convoy 18350 C8 tube, kiriba-ru heatsink head + his mods and spacer to turn it into ANNA-6 (not pictured), SS bezel ground down by kiriba-ru as well. It legos, not as smooth as the Thorfire tube but it works.
Wouldnāt it be great to get a constant current driver with Anduril and limit it to the current you specify?
With my E17A flashlights, Iām using a Convoy Driver for SST40 ,12groups which maxes out at either 5 or 6 amps depending on the size. I then set it to group 8 which limits the current to 50%, so either 2.5 or 3 amps.
Ideally it would be nice to go up to 4 amps, but with the 4 modes up to 50, Iām very happy with the driver and the flashlights get plenty bright. The 0.1 moonlight mode is very low and the driver accommodates a lighted tail switch without a bleeder resistor, which is also very nice.
Recently I bought some 5A/6A Convoy drivers (17mm/20mm simple 4 mode and the 12 groups). They installed single R020 instead of the older ones with R010, I donāt know if another parts might changed too, but it still managed pulling 5-6A at the tail. So you need to make sure before changing the resistor.
