The mailman did me a solid today…wasn’t expecting it until maybe tomorrow. Happy to see the “bunny” snuck in the back door .
Some quick observations:
The threads were pretty dry. Cleaned and lubed. Anduril 2 (yep), substantially different navigation than the straight up Anduril 1 I’m used to. Switch feels pretty solid. I got Nichia 4000k, great tint. Ain’t no lie this little puppy gets scorching hot in short order (Vapcell H10). 10-15 seconds on turbo will curl your hair. Haven’t had enough time to fiddle with the temp throttle, just calibrated base temp. I’m not getting the second flash/buzz to set the threshold. Overall I think it’s fairly impressive.
Been playing around with both of them for a while. These really are great little torches, one question though. In Anduril 2 is the sunset mode default time only 5 min? I know you can add time in 5 min increments. In the original version default was 60 min.
I received my FWAA sst20 4000k today, really happy with the light. The build quality and tail switch feel much better than my first batch FW3A. I can’t believe how small it is too! I’d definitely be in for a titanium or stainless steel FWAA if Lumintop wants to go that direction.
In the ramp mode or candle mode, it's possible to make the light turn
itself off after a while.
To activate the timer, go to the brightness you want and then use a 5H
action. Keep holding the button, and the light should blink once per
second. Each blink adds 5 minutes to the timer.
In ramp mode, it slowly dims until it's at the lowest level, then shuts
off. In candle mode, it stays at the same brightness until the final
minute, at which point it dims and dies out.
The user can change the brightness while the timer is active. If this
happens during the final few minutes, it also "bumps" the timer up to a
minimum of 3 minutes. So if it's getting really dim and you need a
little more time, you could do a 5H to add 5 minutes, or simply ramp up
to the desired brightness.
yep, the DQG Slim AA is indeed a bit longer. I have measured mine at 76,6 mm, 2,1 mm longer than the FWAA. The DQG Tiny AA II (which is of course a twisty) is 68 mm long, 6,5 mm shorter than the FWAA.
I can’t believe it’s that much smaller than the reylight Pineapple… dammit, maybe I will have to order one of these. But I’ll probably just wait for brass to come out, if it ever does. Because it really should - freeme
Arrived today. This is my second Lumintop, and this one is even more impressive with the Anduril 2 driver. Soooo small. I haven’t got my head around the interface yet, but I will.
